Windows 7: Asrick FM2A88X onboard Blown Now Sound Card? Help!
10 May 2014   #31
fireberd
I can't tell you what to do. However, I will never buy another ASRock motherboard because of the problems I had.
10 May 2014   #32
Spudster
Windows 7 Ultimate 64 bit
What does as rock even stand for? There boards are diffintly not rock solid and the audio blew 2 months in not a good start on a new board.
Can see what you mean if I decide to change boards might try gigabyte or Asus.
17 May 2014   #33
linnemeyerhere
You can always add a quality sound card. If sort the ram issue as well. Get a good set of matched ram and a sound card and you're back in business ?
17 May 2014   #34
Spudster
One Question:
I swapped the board with a old gaming board which you can get the specs on my other threads, Too lazy to post it here lol.
How would ddr compared to ddr3 effect gaming.
If I overclocked the CPU what cooling would I need?
17 May 2014   #35
linnemeyerhere
You can't interchange ddr/ddr2 and ddr3 they are specific to the boards requirements only......sorry.
17 May 2014   #36
Spudster
Didn't mean that I already know DDR is DDR and ddr2 is different but does ram speed effect gaming?
18 May 2014   #37
linnemeyerhere
When it comes to ram and it's lanes the faster stable speed you can achieve the better......but the trick will involve the CPU capacity and mobo as well so just buying the fastest listed and hitting XMP or overclocking sometimes other physical limits are hit. I bought 2133 for a 8 core bulldozer rig and could only get 2066 as I remember with the Zambesi 8120 3.2 overclocked to 4.7 and still it was all I could squeeze.
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
onboard sound vs. Addon sound card
What would be the advantages/disadvantages of onboard sound vs a sound card? With a sound add on card are there headers for front panels connections.? Would I see/hear a big difference in the sound?
onboard sound card question
sup fellas, have a stupid question for you... Just switched my desktop to windows 7 from xp pro and have a weird latency with my audio. This latency did not exist on XP, but with 7 it is there. I have been using just my motherboard soundcard (desktop for recording) with the 6 1/8" inputs ......
Enabling onboard sound with a sound card
Hi, I fly MS FSX and I want to be able to chat to ATC with my headphones and then hear the engine noises coming out of my speakers and sub-woofer. I have a soundcard and my motherboard has onboard sound. I can't find the bios setting to turn it on and I can't see any hint of it anywhere on the...
Figuring out onboard sound card
my friends computer has an on board audio sound card that we dont know the name too and the computer was reformatted. Tryin to look up model but not luck, it was built by hand. Any way we could figure this out now? or is it a bit too late. If its late, we could always just buy a sound card, but...
Drivers
