Windows 7: Asrick FM2A88X onboard Blown Now Sound Card? Help!
04 May 2014   #1
Spudster
Windows 7 Ultimate 64 bit
Hello,
So recently my on board audio stopped working for no reason and it doesn't look like it's been fried the board is only 2 months old. Yes I have tried device manager etc it's nothing to do with windows now I inserted a sound I then got my sound back that was great for a few days now Tonight I cleaned up the wiring to make it neater then took out the card to see if the on board would go still nothing so I disabled the on board re installed the card and Now the card is doing the same thing? I tried everything device manager,driver re install etc
With going on
Is the board just faulty and evil to blow a good card or why isn't the card processing sound now?
I am over it is having a working PC a lot to ask for its been causing me a lot of issues since I got it.
I do anything for anyone who can fix my issue
04 May 2014   #2
fireberd
There are many ASRock FM2A88X motherboards, what is the exact model that you have?
With the on-board audio enabled, what is the status in the Device Manager? Does it show working OK or does it have an error code?
04 May 2014   #3
Spudster
It is the Extreme 4+ and it shows working.
Could the bored be destroying everything that gets put in it?
Might get a new bored
04 May 2014   #4
fireberd
In the Device Manager, RIGHT click on the entry for the Realtek sound and then LEFT click "Uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound.
Then go to the Control Panel/Hardware and Sound and finally the Sound Panel/Playback. The "Speakers" should be set as the default playback device.
04 May 2014   #5
Spudster
I will try that in about 20 minutes as it's 7am here starting to get up.
If this doesn't work what else can I do?
Edit: Just tried that didn't work :/
The card is only 4 days old
Thanks for your help
05 May 2014   #6
fireberd
Post a screen shot of the Device Manager, Sound section.
05 May 2014   #7
Spudster
Now all the slots are blown...
Where you put in a graphics/video card
I post a screenshot tommorow getting another bored...
It diffintly not a driver issue
05 May 2014   #8
fireberd
If all the slots are "blown" the only recourse is to get the motherboard replaced. Its still under warranty so contact ASRock. However, they are not the best at resolving issues. I had a new ASRock motherboard with two faulty memory slots and they would only provide a replacement for $50 (US), not free like they should have. I won't be buying any more ASRock motherboards.
05 May 2014   #9
Spudster
$50? If it's not your fault you shouldn't be paying at all
idk if I should get them but found some good as rock boards for $140 on eBay.
05 May 2014   #10
fireberd
I have two other systems I've built in the last two years. One is a Gigabyte and the other an ASUS. Both of these are solid as a "rock"... I have the replacement ASRock board still in the box and won't use it unless one of the others craps out.
The Gigabyte is my recording studio PC.
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
onboard sound vs. Addon sound card
What would be the advantages/disadvantages of onboard sound vs a sound card? With a sound add on card are there headers for front panels connections.? Would I see/hear a big difference in the sound?
onboard sound card question
sup fellas, have a stupid question for you... Just switched my desktop to windows 7 from xp pro and have a weird latency with my audio. This latency did not exist on XP, but with 7 it is there. I have been using just my motherboard soundcard (desktop for recording) with the 6 1/8" inputs ......
Enabling onboard sound with a sound card
Hi, I fly MS FSX and I want to be able to chat to ATC with my headphones and then hear the engine noises coming out of my speakers and sub-woofer. I have a soundcard and my motherboard has onboard sound. I can't find the bios setting to turn it on and I can't see any hint of it anywhere on the...
Figuring out onboard sound card
my friends computer has an on board audio sound card that we dont know the name too and the computer was reformatted. Tryin to look up model but not luck, it was built by hand. Any way we could figure this out now? or is it a bit too late. If its late, we could always just buy a sound card, but...
Drivers
