Windows 7: Sound jumping from normal volume, to extremely low.
08 May 2014   #1
matt89
windows 7 ultumate 64 bit
So for the past few days, whilst watching youtube or playing a video game, I have noticed that my computer's sound has bounced from normal volume to extremely low. Nothing seems to effect it, as it does it randomly. I have changed out wires, and speakers (I only have my center speaker hooked up as I am moving soon and didn't want to wire up the entire room). It is not the speaker, the wire from the computer to the amp, or from the amp to the speaker. Now the sound seams to be stuck at the low volume, and I can only hear the bass unless I turn the volume up- in which case it sounds fuzzy. JVL audio wave series HD 707
08 May 2014   #2
fireberd
Can you try a headset, in the front panel headset jack, and/or the rear GREEN speaker jack to see if the problem is also with a headset or if it is working OK with a headset.
08 May 2014   #3
matt89
Thanks for the reply, yes headset works in both front and rear port, I also hooked my surround speakers up and they work fine. It seems to be only the center channel. I connected my center speaker to another output (front left I think it was) and the speaker works fine.
09 May 2014   #4
fireberd
The headset working suggests the PC sound is OK. Center by itself won't really work correctly. You need the entire surround sound system connected, not just the center speaker.
09 May 2014   #5
matt89
Center by itself has worked correctly for the past month. The entire surround is connected and the center is still low volume while the rest of the system is at full volume.
09 May 2014   #6
fireberd
From your first post, it sounded like you were only using the center speaker and connecting it to the GREEN speaker jack. That works OK with headsets so if that is the case the problem has to be external of the PC.???
Am I confused on what you actually have?
09 May 2014   #7
matt89
Ok sorry let me break it down. I have a cable running from my green jack to the bass, which distributes the rest of the wiring to the speakers. I only had my center speaker hooked up at first, but when all my efforts showed that I couldn't fix it, I hooked up the full surround. All speakers work, and when I disconnect the center speaker from the center output, and say, reconnect it to any other output- the speaker works. It looks like for some reason the center output is not working correctly... May be that the output directly from the bass isn't working properly... I hope not hah.
09 May 2014   #8
fireberd
If I understand you only have one cable connected to the Green speaker jack on the PC and all the speakers feed from the speaker's bass unit (which has all the amplifiers in it). If this is the case then there is a problem internally in the speaker system.
However, normally with a surround sound system there are three connections between the PC and Speaker system's bass unit.
Extremely little free memory, I don't think this is normal...
I tried using Google for this, also searched the forum, didn't find anything that answered this question, so I've decided to just open up a topic. My PC has 16 GB of DDR3 RAM. According to task manager, I have 16,302 MB Total, 12,549 Cached, 13,188 available, and only 692 "free". Should my free...
Performance & Maintenance
No Sound Boost Bar Extremely Low Mic Sound
I have no boost bar in the mic settings. I have no idea why. The worst part is that Windows 7 is making my mic ultra quiet. Its pretty much in my mouth. How do I fix it? The Mic works great on my Mac and consoles but on my Windows 7 PC the mic volume is ultra low.
Extremely low volume in headphones/speakers
Good day, I'm using a fairly new HP Mini netbook and ever since I got it I have this problem of low volume in plugged in headphones and speakers. The netbook speakers themselves are pretty fantastic, but if I plug in headphones or speakers, it seems that the computer lowers the volume...
Volume extremely low, found no fix via google
EDIT: I just found out that this is most likely because my driver thinks the speakers are plugged in and lowers the sound. I tried on another computer, once in the speaker jack (it was low), then in the headphone jack (it was high). Would it work if I made the speaker jack a headphone jack by...
Extremely low sound from earphones...Help!
I have a XFX nForce 680i LT SLI board with onboard Hi-Def. Using Win7 Ultimate 32bit. I use my Blackberry earphones plugged into the back panel green jack. Never had any problems with this setup until about a week back. A week ago, without ANY apparent reason (no new programs/drivers...
Extremely low volume on headphones but high volume on speakers
y0 I got this other problem i really hate. The most. Please jonathan_king, zigzag reply please. I beg you, i got this problem that i plug in my headphones and its extremely low volume. It use to work fine, but now nope. I tried the jacks on the front, back and my monitor. Please help me.
