Windows 7: No Speaker audio - Headphone audio okay
10 May 2014   #1
jrj350
Windows 7 Home Premium
Quote:
HP 200-5120IS
Intel Pentium E5400 / 2.7 GHz
Dual-Core 64-bit
Chipset Type Intel G45S Express
Data Bus Speed 800.0 MHz
RAM - 4 GB DDR3 SDRAM - Non-ECC
HD - 500.0 GB - Standard - Serial ATA-150 - 7200.0 rpm
Sound card - Integrated
My wife has a dual boot operation using Windows 7 and Ubuntu 14.04.
Here is the situation:
There is no audio in Windows 7 through the speakers.
The audio is okay in Windows 7 through the headset.
The audio is okay in Ubuntu speakers and headset.
I can't determine what happened to the audio through the speakers, in Windows 7. Troubleshooting has led nowhere.
Any possible suggestions woiuld be appreciated.
Thank you
10 May 2014   #2
fireberd
Does the HP PC have the correct sound driver for Windows 7? or is it only using the generic, basic function "HD Audio Codec" that Windows will install?
Here is the HP listing and the RealTek audio driver.
Software & driver downloads HP All-in-One 200-5120is Desktop PC | HP® Support
11 May 2014   #3
jrj350
@firebird
Yes, it has the correct RealTek driver. As I mentioned, the sound works perfectly through the headsets. Also, when clicking on the small speaker icon in the lower panel) the audio meter is registering, indicating audio is there.
11 May 2014   #4
fireberd
Check the Control Panel/Hardware and Sound and finally the Sound Panel Playback section. The "Speakers" should be set as the default Playback device. You can also test the speakers in that panel.
11 May 2014   #5
jrj350
@fireberd
Speaakers are set as default and I tried to test them but no joy. I feel there is no mechanical problem here because the speakers work very well in Ubuntu. I'll recheck those things you mentioned, just to make sure I haven't missed anything.
I do appreciate your inputs.
how to turn off audio from speakers while using headphone?
Hi,Everyony I just installed windows 7ultimate 32bits yesterday on my 4 computers. but now i am facing a problem on all computers. when i plug the headphone stereo pin then the audio voice come from headphone and also from computer's built-In speakers I check from font and back side of...
Audio 2.1 Speakers+Subwoofer, one speaker not outputting audio
Hi, hope you guys can help/guide me out. So I receive a gift a couple of months ago, but did not have the chance to test it until now. I have a set of audio speakers+sub-woofer, if you take a look at the pics (specially the back.jpg) the speakers are connected through a RCA cable, and where...
Audio coming from both Headphone and Speakers when headphone used!!
Hello Guys, had this problem while,tried many of the solutions to resolve and failed,finally reset the system to factory settings thinking things will be back to normal,but still it exists!!:cry: *Asus g74sx- windows 7 ultimate,Realtek Hd audio. Just saw the new Realtek Hd audio driver...
Sound coming from both headphone & speaker but headphone is not detect
I have Lenovo 3000 Y410 laptop having Windows 7 Home Premium installed on it. Realtek HD Audio latest driver is installed. But from the last 3 days, when I connect headphone through laptop, following things happen : - 1) Headphone connected popup doesn't show up. 2) Mic of Headphone connected pop...
Headphone audio problems.
After powering on my PC today, I noticed a light high pitched ringing noise coming out of the left side of the headphones. I then tried to play some music, and had very low levels of sound coming out of the left side, while the right seemed seemed to be working fine. Does anyone have a general idea...
Help. Audio is much quieter in right speaker/headphone.
Hello, I am running windows 7 home premium 64 bit on a new Dell Inspiron 14z -5432 laptop with built-in skull candy speakers and Maxx audio. the Audio in the right speaker is much quieter than the left speaker. I checked the drivers and the L/R balance and all were OK. The problem continues when I...
