I'm in a mess with sound - help!
imacken
Power User
12:46 AM
Guys,
Can anyone help here?
The only problem I have with Win7 is sound.
I use a Audigy via digital 5.1 output to my Creative 5700 receiver via optical cable. In Vista (and XP before) everything is great.
In Win7, I get output, but after a while I get distorted buzzing and playing some games, the sound cuts out completely.
I've tried some of the suggested fixes, e.g. changing to high sample rates, using Daniel K's drivers, etc. to no avail.
So, I decided to try the onboard Realtek sound. I installed the 2.14 drivers, and although the sound seems quite stable, there are 2 problems:
1) the quality is poor. there is no depth to it. Is there a equaliser (or something else) that can boost bass and treble?
2) I can only get 2 channel stereo. No option for selecting 5.1 or anything that I can see.
Can anyone help with any of this? If I bought a newer card (X-Fi Extreme?) would that solve the problem?
Thanks.
Windows 7 64-bitIntel i7 920 @ 4GHz6GbnVidia GTX 285
Windows 7 64-bit
Intel i7 920 @ 4GHz
Asus P6T Deluxe V2
6Gb
nVidia GTX 285
X-Fi Extreme Audio PCIe
1900x1200
Airbot 2.0
Zotac Geforce GTX 770
ASUS Xonar D2X
1920x1080@60hz
1 Samsung 250GB 840 Evo SSD
1 OCZ Vertex2 180GB SSD
Pioneer DVD Burner DVR-S18M
Corsair HX1000W
Cooler Master HAF 932
Logitech Wireless MK700
DL 15 Mbps UL 0.98 Mbps
None
Firefox Nightly
*Phone- LG Nexus 5
Yes, the problem is my setup doesn't have any of these options as I don't have speakers attached to the on board audio. I use the optical out into my receiver.
Any ideas?
Windows 7 64-bit
Intel i7 920 @ 4GHz
Asus P6T Deluxe V2
6Gb
nVidia GTX 285
1900x1200
Any ideas?
Hi imacken,
Try right clicking on the Digital output device this should give you some options
Windows 7 Ultimate x64Intel Core i7-2600K16 GB G Skill F3-10666 CL9D-4GBRLATI Radeon HD 6870
Something I threw together
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
ATI Radeon HDMI / Realtek ALC892
2 x 22" standard monitors / LG32LC56v TV to watch films
1920 x1080
2 x OCZ Vertex2 111.79GB
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
1 x Hitachi5K320-160
Thermaltake Toughpower Cable Management 750W
Antec 300
Noctua NH-U12P SE2 and 5 120mm Case fans
Microsoft Comfort Curve Keyboard 2000
Hama M3110 / Logitech M305
I have also used Fedora, Suse, Ubuntu Linux
And all other Windows from 95 to date except ME
Thanks. Yes I do have these options, but they don't really help. I have no way of selecting 5.1 speakers in menus.
For years, working with my Audigy was simple:
1) connect via digital din to my 5700 Inspire
2) select 5.1 on the 5700
2) go to 'manage audio devices' in Control Panel, select 5.1 and test.
Then when I'm, playing games I get full surround sound, i.e. if I move 360 degrees, then if someone is talking to me in the game the voice goes full front to back etc.
I can't achieve this with the Realtek sound.
Windows 7 64-bit
Intel i7 920 @ 4GHz
Asus P6T Deluxe V2
6Gb
nVidia GTX 285
1900x1200
I had hoped that maybe you could have sorted the distortion.
a newer card (X-Fi Extreme?) might solve the problem I really cant say, you would have to try it
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
1920 x1080
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
Antec 300
