Windows 7: 5.1 audio system problem
11 May 2014   #1
alexlikEEEE
Hi, first off all sorry for my bad english.
A couple a days i've bought an audio card Asus Xonar DGX. I own a Logitech Z506 and my sound is not 5.1 . I hope u guys could help me...i installed the driver and my center and rear speker don't work. only 2 or 3 speakers work. Cheers
11 May 2014   #2
fireberd
First, disable the integrated audio (on the motherboard audio) in the BIOS. This will prevent any conflict since you now have a separate sound card.
The Speakers need 5.1 selected. Go to the Control Panel/Hardware and Sound and finally the Sound Panel, Playback section. Click on Speakers (the Xonar DGX) to highlight it and then click the "Configure" button at the bottom left of the panel. In the Speaker Configuration Panel, select 5.1 and you can also test the speakers there.
Here are some screen shots (I have RealTek but yours will be the Xonar).
5.1 audio system problem-sound-playback-panel.jpg 5.1 audio system problem-speaker-setup.jpg
11 May 2014   #3
alexlikEEEE
Hi, thanks for answer i've already done this but when i press test buton i can't hear center speaker. I don't know why but i don't hear as i said 2-3 speakers when i play a movie or a game
11 May 2014   #4
fireberd
If it does not work with the Test, there is either a problem with the speaker system, a connection problem or a problem in the ASUS Xonar card. If the ASUS Xonar has a configuration panel, check that to see if the 5.1 is set up correctly.
12 May 2014   #5
alexlikEEEE
the center speaker is working tested in other port. The problem is the driver. Can u guys give me some moded drivers or something like that?
12 May 2014   #6
fireberd
I don't know of any modded drivers.
23 May 2014   #7
alexlikEEEE
hey. sorry for answering so late. i've been gone out of town.
I don't know why it's keep reseting to stereo when i set 'em on 5.1 in Speaker Setup
23 May 2014   #8
Wordsworth
Windows 7 Ultimate 64 bit
You should be able to correct problems with the center and rear speakers not working in the Asus software. Below you'll see the Asus software. At the left side near the center of the picture where it says Audio Channel, what that really means is you select from the drop down box what your source material is. In other words, if you are playing stereo material (CD for example) you'll set that to 2 channels, then your Analog Out to 5.1 speakers and get music through all 5 speakers plus your subwoofer. You can add more surround affect using 7.1 Virtual Speaker or Dolby Pro Logic as well.
If you want simply stereo music from a CD or MP3, keep the Audio Channel set to 2 Channels and set the Analog out to 2 speakers. If you are playing a movie that has 5.1 output, you set Audio Channel to 6 channels. Make certain your Analog Out is set to 5.1 speakers and you're set.
By the way, you'll find that if you open the Asus software and the Windows Sound software that whatever you select in the Asus software under Audio Channel, the Windows Sound software will change with it. For example select 2 channels and the change is reflected in the Windows software, and the same if you select others, 4 channel, 6 channel, etc.
Audio CD - RAW File System
Hi All... Not sure if the is the correct forum or not.?? A colleague at work gave me a music CD to listen to today (Digimax CD-R x52), but when I got it home to listen to on my laptop, I could not see the data on the disk.?. Using Disk Management I was able to see that the under "File...
Music, Pictures & Video
Audio problem, Audio device is disabled.
I turned on my laptop the other day and no audio would play from anything, like youtube videos or itunes. I checked my volume control nothing was muted. When I opened itunes I got a message saying "itunes has detected a problem with your audio configuration. Audio/video playback may not operate...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Record System Audio
I know this question has been pondered to death, but I haven't been able to find a solution, and it's really irritating me. So, as the title states, I would like to be able to record the audio coming through my computer. The problem is I only have one audio jack, which is only line out (I use a...
Good audio for my new system
I am very new at audio, been looking around online and it seems like the Klipsch ProMedia 2.1 are well regarded. The other option seems to be a Polk Audio PSW10 sub paired with their Monitor 30 II bookself speakers. Thoughts?
