Windows 7: Sound settings reset after reboot
28 Oct 2009   #1
Windows 7 64-bit
I'm having lots of problems with Windows 7 64-bit.
One of them is that my sound settings (volume, bass, surround sound, etc...) are being reset every reboot.
I'm using the Creative X-fi Xtreme Gamer sound card with the latest Windows 7 64-bit drivers from their site. I've disable UAC, messed around with permissions and nothing seems to work. I have to go into the audio settings every time I reset!
Please help! Thanks
29 Oct 2009   #2
do you play games or play dvd movies on your computer? I have the same problem that you have and everytime a dialogue comes, like 2 people talking to each other in a DVD movie, or sometimes in video games the sound is really really soft...
10 Dec 2009   #3
windows 8.1 Pro x64
same problem, I use zoom player, first use I had to jack it up to 80% from very low.
after a reboot it resets back to the default low setting, I can see this been a pain if every app starts doing this.
22 Dec 2010   #4
Windows 7 64-bit
Sorted this one out myself. Creative were at fault with either their hardware or driver. Basically I switched to an Asus Xonar soundcard and never looked back since!!
22 Dec 2010   #5
same with me sir ..
in the speaker application ..
when reboot ..
the some sounds are reset ..
problem of this ?
sorry for my bad english
Search this Thread:
Advanced Search
Dual monitors positions reset after every reboot.
I have two monitors, a Samsung SyncMaster S24B300 (1080p) in landscape mode, and an Envision H193WK (1440x900) in portrait mode. The 1080p monitor is aligned to the right of the other one. I set them to -900, -100 and they align perfectly (mouse travels straight across screens), but despite saving...
Graphic Cards
How do i reset registry settings
I have windows 7/ 32 and i am looking to restore the registry settings back to factory. I once had a little tool from here something like RESTORE_regisrty.reg or if you no of this tool , or any other way that you may no how thanks.
General Discussion
How to reset browser settings????
Here is my problem. I enjoy working jigsaw puzzles online. Sometimes when I click on a piece of the puzzle, move the cursor to place the piece where it goes, the piece is dropped and I have to re-click on the piece to move it. Sometimes this happens a couple of times before I get the piece set. ...
Browsers & Mail
Reset CMD to default settings?
I need to reset my CMD to it's default settings how do I do that? I am using Windows 7 Ultimate 32 bit..
General Discussion
Option Settings Reset After Reboot
Here is the problem - 2 examples: 1...I adjust my touchpad speed...after a reboot, the speed is back to "default?" what it had been before I had adjusted it. 2...Even my email - I adjust the size of attachments that are allowed to be downloaded, and after reboot it is back to what it had...
Performance & Maintenance
Sound Mixer Doesn't Retain Settings After Reboot
I get all of the sound settings exactly how I want them, and invariably upon rebooting, all of the sliders go up to the maximum. This is somewhat annoying, but even more so for some apps, like my email client, which is set to play a sound when an email is received. The reason being that the...
