Windows 7: Audio Recording Level of G-Track Mic Jumps up randomly to 100%
14 May 2014   #1
cantorgreen
Windows 7 Professional SP1 64 bit
Hi
I have a G-Track Mic. Per other posts in this forum, the mic prefers it when the recording level in Windows for that device is set at 8%. I change it to 8%, and randomly -- and regularly (sometimes even in the middle of a recording in Magix Samplitude), it jumps back up to 100%, causing overload and ruining my recordings.
Any way to keep that recording level at 8%???
Thanks for the help.
Jason
14 May 2014   #2
fireberd
I have a recording studio, using Sonar X3 Producer, but don't use USB mics or the PC's sound card. My recording interface is a Roland Octa-Capture.
How are you connecting the mic? Directly to a USB port? or through an external USB hub? If its not direct, try that. Also, if you are connecting to a front panel USB port, try a rear USB port. It may be the internal USB hub and some other device is affecting it.
Also try it with some other recording program, to see how it reacts. Audacity is one to try. I'm not sure if the built in Windows Sound Recorder will work with a USB mic.
14 May 2014   #3
cantorgreen
I am in fact going into the front USB port. It's now in the back, and so far so good... Interestingly, plugging it in the back triggered an auto-update of the Windows Drivers, which may have helped.
I'll try your other troubleshooting tips shortly if I need to. Thanks for writing back so quickly.
Jason
USB Condenser Mic Recording Volume Level
Hi guys, basically I have purchased a behringer c-1u, of course before I did some research and there were issues with the volume. Now that I have it, I have the same issue that many people with the mic also have, and that is with the volume it records at. In the windows sound mixer the...
Wireless mouse cursor randomly jumps around.
I have the EW-6000 mouse Case Logic Optical Wireless Mouse 2.4 Ghz EW-6000 Black | Walgreens,It is brand new I just brought it yesterday and it came with fresh batteries with it. But my cursor randomly jump's around, Its like its drunk. edit: Oh, i forgot to say that i have a usb 1.0 or 1.1...
Hardware & Devices
Recording level keeps changing
I am using Sound Recorder. I have adjusted my Microphone level using the Recording Devices via a right click on the speaker. But as I record the level keeps decreasing. I adjust it back up then then later I see it decreased again (often to a level that it doesn't record enough to even hear it in a...
Line Level Input Recording Volume LOW / QUIET
I have Xonar D1 with Windows 7 x64 using Sound Forge 9.0e to capture audio from Line Level inputs (LPs played on stereo system). The recording level maxes at -12Db to -15Db. This of course artificially restricts the dynamic range. All settings are maxed in the Xonar D1 control panel as well...
Battery Level Jumps Up and down
Its strange but my battery goes from 16% to 23% (Or etc% To etc%) in one minute, once when I get down to about 10% I have to hurry and find my charger because that is no longer accurate.. Does this mean my battery wearing out? The battery and the computer is one year old.
Performance & Maintenance
Cursor jumps randomly
I replaced Vista with Windows 7 using a clean install. My wife's laptop came with Windows 7 preinstalled. On both of our machines, the cursor occasionally jumps to a different location while typing. (Example: in an email reply, it will jump from the reply I'm typing down to the previous...
BSOD Help and Support
