Windows 7: Sound issue !
14 May 2014   #11
Simply27
Windows 7 x64
Try installing it in Compatibility mode for Vista. Right Click on the Install Icon and then Left Click Properties. One of the tabs in the Properties panel will be for Compatibility.
Yes now it said succes,what should i do now ?
14 May 2014   #12
Simply27
Windows 7 x64
The conexant driver installed succesfully but the issue still exist
14 May 2014   #13
fireberd
Is the Conexant set as the Default Audio Playback device? in the Control Panel/hardware and sound and finally the Sound Panel Playback section. Also in the Sound Panel, click on the Recording Tab. If it has Stereo Mix (could be called System Mixer) set that as the Default Recording Device.
in the Device Manager, the Conexant should be listed. Also, if the HD Audio Codec entry is still there uninstall it.
Finally, if the Conexant has a control panel (would probably be listed in the Control Panel/Hardware and Sound section, check that for any configuration options.
14 May 2014   #14
Simply27
Windows 7 x64
Yea did all what you said and now everything working after a restart.
Thank you very much !
14 May 2014   #15
fireberd
Great. Glad I was able to help you.
 Sound issue !
Reoccurring low sound issue affecting two sound cards
I had this issue before, all of a sudden the sound coming from my computer gets really quiet even though everything is maxed out. Before, it seemed to have been triggered when I moved my computer from one room to another. I wasn't able to move it back right away but when I did it was still...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Sound issue
http://www.facebook.com/photo.php?fbid=10151290051553689&set=a.150914573688.136450.672368688&type=1&theaterHello, Everything worked fine yesterday no programs or changes to pc. This morning no sound. Under control panel individual device has fluctuating sound indicator. Under volume mixer...
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Sound issue (Conexant sound driver)
Ok, first of all, i'm not sure how to properly explain this, because it's confusing, but i'll try my best and if any more information is needed please let me know! So, I bought this packard bell laptop preinstalled with windows 7 from pc world in September. And for as long as I can remember,...
Big sound issue!
Hi every1 on 7 forum! I'm new here and my English is not so good so please don't get angry by it. I'm a hugh fan of my 7 OS and I wouldn't change it for anything (first thing to know). On my job I work on CentOS remote server with no GUI and it is hard to learn it so I decided to shrink my C...
