Windows 7: Sound issue !
14 May 2014   #1
Simply27
Windows 7 x64
Sound issue !
Hello everyone !
I have a HP Compaq Presario v6000,and i reformated to windows 7 and i have a sound problem with my laptop.
The sound works on laptop speakers,but when i plug in headset and microphone the sound doesn't go to headset but it still on the laptop speakers.
I plug in the headset and microphone and it doesn't show in the playback or recording devices tab.
Please help !
14 May 2014   #2
Gator
Dual Boot: Windows 8.1 & Server 2012r2 VMs: Kali Linux, Backbox, Matriux, Windows 8.1
Hello simply and welcome to Seven forums!
Can you post a picture of your Device Manager?
Go to Start > In search start typing "Device Manager". You will see "Device Manager" in the results.
Next, expand Sound, Video and Game controllers. You can then use the "Snipping Tool" (same process as above but search for Snipping Tool)
Next, highlight the area around the Device Manager windows and save it to your Desktop. Come back here and click the Paper clip Icon next to the Smiley face. Click "Browse" and then find your snip on your desktop and upload it.
14 May 2014   #3
Simply27
Windows 7 x64
Here it is,in the device manager it shows that is ok :
14 May 2014   #4
Gator
Quote   Quote: Originally Posted by Simply27 View Post
After you click Browse, make sure you select "Upload" as well
14 May 2014   #5
Simply27
Windows 7 x64
Ye got it.
14 May 2014   #6
Gator
Did you update all of your drivers after you reinstalled ? You should have a disk with the drivers necessary that came with your PC. If not, go to the link below.
Go here, it should automatically detect your product and you can download drivers from there.
NVIDIA Driver Downloads - Automatically Detect NVIDIA Products
14 May 2014   #7
Simply27
Windows 7 x64
Leatest driver from nvidia on my laptop is GeForce 307.83 Driver.
When i try to install the driver a problem pop up "Install Cannot Continue - The Graphics Driver Could Not Find Compatible Graphics Hardware."
I found fix in this website https://forums.geforce.com/default/t...re-installer-/
I have follow all the steps but in the step 7 i don't have the inf files.
7. there will be many INF files there of the type:
nvaa.inf
nvac.inf
nvam.inf
nvao.inf
nvbl.inf
14 May 2014   #8
fireberd
Looking at the screen shot of the Device Manager, I see "High Definition Audio Device" which is usually the generic, basic function, Windows installed sound driver. First step is to get the correct sound driver and install that.
HP lists a Conexant Vista driver for this model. The Vista driver is applicable to Windows 7.
Conexant High-Definition Audio Driver - Compaq Presario V6003AU Notebook PC | HP® Support=
14 May 2014   #9
Simply27
Windows 7 x64
Just downloaded and was trying to install but it won't install it says failure
14 May 2014   #10
fireberd
Try installing it in Compatibility mode for Vista. Right Click on the Install Icon and then Left Click Properties. One of the tabs in the Properties panel will be for Compatibility.
 Sound issue !
Reoccurring low sound issue affecting two sound cards
I had this issue before, all of a sudden the sound coming from my computer gets really quiet even though everything is maxed out. Before, it seemed to have been triggered when I moved my computer from one room to another. I wasn't able to move it back right away but when I did it was still...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Sound issue
http://www.facebook.com/photo.php?fbid=10151290051553689&set=a.150914573688.136450.672368688&type=1&theaterHello, Everything worked fine yesterday no programs or changes to pc. This morning no sound. Under control panel individual device has fluctuating sound indicator. Under volume mixer...
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Sound issue (Conexant sound driver)
Ok, first of all, i'm not sure how to properly explain this, because it's confusing, but i'll try my best and if any more information is needed please let me know! So, I bought this packard bell laptop preinstalled with windows 7 from pc world in September. And for as long as I can remember,...
Big sound issue!
Hi every1 on 7 forum! I'm new here and my English is not so good so please don't get angry by it. I'm a hugh fan of my 7 OS and I wouldn't change it for anything (first thing to know). On my job I work on CentOS remote server with no GUI and it is hard to learn it so I decided to shrink my C...
