Windows 7: audio not working leading to blue error screen and restart. help!
16 May 2014   #1
muddly
64 bit
Hi
hi, my comp is having some audio problems and I really need help. -windows 7 ultimate 64 bit-
I haven't been able to start up windows properly without a blue screen followed by restart. I can only start in safe mode.
It says one or more audio services aren't working.
it says i have no audio playback device installed. One or more audio service isn't running.Both the Windows Audio and the Windows Audio End Point Builder services must be running for audio to work correctly. Atleast one of these services isn't running.
looking at a previous thread, when I checked services. My windows audio and audio end point are at automatic, however when I check properties>discrepancies, there is not information.
What do I do??
16 May 2014   #2
Damian Adelle
Windows 7 Ultimate 64bit
Hey muddly, welcome. So, an Acer Aspire huh?, I always have trouble with these, I don't know why . Acer doesn't like me at all. Did you installed the OS and drivers yourself?, or it came like that from the OEM?
16 May 2014   #3
muddly
64 bit
Hi Damian, it came from the OEM, i did do a system restore , so that might have been the problem, but i dunno hw to fix it.
16 May 2014   #4
Damian Adelle
Quote   Quote: Originally Posted by muddly View Post
This started as soon as you restored the system?
16 May 2014   #5
muddly
64 bit
Well it happened once or twice and then i used system restore, and now its become everytime i switch on my laptop on normal mode. Do i need to go to a computer service shop?...
16 May 2014   #6
Damian Adelle
Well mud, you probably need to start by checking why the OS is giving you this BSOD, try this (since you are able to enter the OS via safe mode:
Blue Screen of Death (BSOD) Posting Instructions
My guess is that this is related to a driver, but let's make no conclusions and try to see what's happening, maybe if someone else had this trouble before already knows the answer, but right now, you can start by checking that BSOD info available.
Got a blue screen error and now my wireless is not working
With cable the internet works fine.I don't want to send to support because they will format.
BSOD Help and Support
Windows Update error 780 - leading to Blue Screen Crash
Hi Team, I am unable to update my windows 7 64bit home premium, due to the above error mentioned. Went through the steps of help below, but I cannot find SQL Server VSS Writer program installed in my system, please let me know where to find this program to download and install it. Due to this...
Windows Updates & Activation
BSOD - Screen goes black and upon restart tells me I got a blue screen
This can happen at any time for me (including when I was re-installing windows in an attempt to fix the problem... did not go well :p) but more often than not happens during web-browsing and especially when watching youtube vids. I'm going to assume it has something to do with my graphics card as...
Random Blue Screen and Restart
I was using my laptop when all of a sudden the blue screen appeared and restarted automatically. and also additional info. my laptop's battery is broken for several years no so i used the adapter for power so i think that might have cause some problems with the way i used my laptop. i uploaded the...
Windows 7 Blue Screen Error and Laptop Restart
Hi All, I am a new member to this forum and need experts help on resolving the Windows 7 Home Premium Blue Screen Error that I am facing while downloading Games/Any files via the Bit Torrent software. My Laptop is a brand New Dell Inspiron 15R Intel core i5 system and I am facing this restart...
Blue Screen almost instant on restart (Different)
I read the other blue screen threads, but none seemed to help me out. I did not want to interfere with the other person's problem so I started this thread and I will attach the zip file of the most recent blue screen. This Blue screen is happening when My computer is barley running anything. I...
