Windows 7: Sound problem stops
31 May 2014   #1
aaronnz
Sound problem stops
Good morning.
My laptop speakers have some sort of problem with them.
When you go to play music it plays but stops half way through. If you put a portable speaker system in, or headphones it plays perfectly fine.
Could it be something to do with the sound driver?
31 May 2014   #2
fireberd
Please fill in the "My System Specs". It helps us to try and help you.
When that happens, check the Control Panel/Hardware and Sound and finally the Sound Panel/Playback section. Check that the "Speakers" are still set as the default playback device.
 Sound problem stops
Sound Randomly stops
Hi people. Having an annoying issue that's started occurring the last couple days. As the title says my sound is dropping out at random times. I've noticed it has occurred when my computer stops performing a task with sound. It has stopped after playing a game, watching a movie and listening to...
Sound intermittently stops
Sound intermittently stops while I'm using Windows Media Player, Movie Maker, etc... I dont use the onboard sound. I use an USB Native Instruments interface to connect the audio inputs/outputs, the Asio driver is updated. My Win7 is updated too. I read on this forum about disabling...
Monitor Stops All Sound
I recently had an update. Before the update I could use a second monitor through a HMDI cable and it will not halt sound. Now after the update whenever I have my second monitor plugged in all sound stops. I have to unplug the second monitor to get my laptop to play sound again. :confused: I have...
Sound Suddenly Stops During Gaming
Hi, (This is a re-post of a thread I originally posted in the Sound & Audio section of the forum and was advised to try here) I think that Windows might be disabling my sound device during gaming because it thinks it is idle. I don't know if this is the exact reason but after much testing have...
Gaming
Sound stops when changing audio input problem
Hello, I have a standard 3.5mm output jack on the back of my motherboard, whenever I change the jack, e.g. take speakers out, plug headphones in, the sound stops, usually when i'm using itunes, or bbc iplayer. Sometimes this can crash microsoft messenger as well. I have to restart the...
sound stops
I have an HP Pavilian DV7 basic build config was with win vista I upgraded to win7 ultimate. My issue is every few days or each day just random my sound stops working all together, i click the lil "sound icon" next to the time and clock on the taskbar it shows that there is sound to be played...
