Windows 7: Help Needed. Audio Problems
03 Jun 2014   #11
Kepler
Windows 7 x64 Home Premium
Ive done everything you said. Still nothing. Im hoping it not my motherboard as ive waited ages for this and dont fancy sending back
03 Jun 2014   #12
Kepler
Uninstalled audio drivers, rebooted, installed audio drivers, rebooted. Still same problem. Really hope its not the motherboard dont fancy reverting back to my old one
03 Jun 2014   #13
fireberd
Sadly, it would appear to be a problem with the sound chip on the motherboard.
If you have a separate sound card that you can install and use, you could try that (disable the on-board in the BIOS when you use a separate sound card).
Help needed in HD Audio and installing Realtek drivers.
Ok so lets get started. This is my first post.Below described is my PC's rig AMD FX6300 Gigabyte GA-78LMT-USB3 Galaxy NVIDIA 630 2gb ddr3 4 gb ram and 500gb hdd my problem is that I hear only one sided audio from my headphones when I connect the HD Audio pin on the board. And when I insert...
Front Panel Audio connector help needed
So I basically have a very odd front panel audio connector setup, very confusing, I've made over 10 thread on different forums and non were able to help me. I'm using a Gigabyte G31 motherboard GIGABYTE - Motherboard - Socket 775 - GA-G31M-ES2L (rev. 1.x) Manual page for the motherboard...
Hardware & Devices
Organising Audio files - help needed
Hi guys, I've been away from WMC for a long time, but having now seen it working under W7, I was thinking about trying it again. FYI I've been using the Jriver Media Centre in the meantime. Apologies if this is basic stuff, and feel free to direct me elsewhere if necessary. So I've got loads...
Media Center
Audio drivers needed
Hi, everyone. I've recently installed Win7 on my ASUS A8V-VM-SE mobo. Win7 has found every driver except for the sound... Well, actually it has found a driver but it's showing (S/PDIF) for some reason not AC'97. I need an AC'97 driver but cannot find one that works with this mobo. I've tried...
Audio Player, Organizer Advice Needed
Hello everyone, I need an audio organizer/player that will play MP3s and WAVs, allow me to compile a list of certain songs from various sources (MP3 files, “burned” CDs), then for those songs without or with incorrect ID tag information, I need to edit the “tag”, then save (“export”) all of the...
Music, Pictures & Video
Sigmatel 97XX C-Major Audio Driver Help Needed!
I have an older P4 2.8ghz Dell Dimension 3100 that currently has Windows 7 installed. Apparently the driver is the Sigmatel 97xx C-Major audio according to support.dell.com - the first thing I tried was the Windows Vista driver listed on Dell's site. Unfortunately that did not work. The driver...
