Help Needed. Audio Problems
  1. Posts : 7
    Windows 7 x64 Home Premium
    Heres the problem
    When i connect headphones to rear sound panel (Pink + Green)
    Sound does not play out of my left speaker but mic works fine.
    When i plug headset in front sound ports (Pink + Green)
    Sound plays fine in both speakers but mic does not work
    I use my rear sound port for the speakers on my monitor and use the front sound ports for my headset.
    Uninstalled drivers and reinstalled (No luck)
    Rebooted OS Fresh Install (No Luck)
    Used old drivers (No Luck)
    Used new drivers (No Luck)
    The headset is working
    Motherboard ASrock FM2A55M-HD+
    Tower Case CiT 1017
    Can anyone help me. ive tried everything i can think of
    Disconnect the front panel audio connector on the motherboard. Then try the rear Green speaker jack to see if you have both channels. If the sound works OK with the front panel disconnected, the problem is most likely in the front panel or connector.
  3. Posts : 7
    Not worked. Its not the tower. I tried the front audio ports on my old tower and still have the same problem. I know it works as it worked before. I want both speakers working on the rear of my tower and i want the mic working on the front panel. Its either a software fault or hardware fault
  4. Posts : 8,135
    Did you disconnect the front panel, as I suggested and then tried it?
    What sound do you have? RealTek? or some other sound type?
  5. Posts : 7
    Yes i disconnected the front panel. Sound is Realtek HD Audio. downloaded the latest drivers from Asrocks website
  6. Posts : 8,135
    Try the High Definition Codec driver direct from RealTek. It will work as I have that installed on both of my desktop systems, one with a Gigabyte motherboard and the other with an ASUS motherboard.
    Realtek
    Also what do you have listed in the Device Manager, Sounds section?
  7. Posts : 7
    These are the only things in my sound
    AMD High Definition Audio Device
    Magic Sound (Webcam Mic) Disabled
  8. Posts : 8,135
    What is in the Device Manager is OK and would not cause your problem.
    Along with the direct from RealTek drivers, check the RealTek HD Audio Manager, for setups.
    Here is mine:
    Attached Thumbnails Attached Thumbnails Help Needed. Audio Problems-capture.jpg
  9. Posts : 7
    Still not working. Now doesn't recognize front panel after plugging back in
  10. Posts : 8,135
    Did you get it plugged back in correctly? Its keyed but it still could be plugged in partially or wrong.
    Also, did you power off and unplug it, same way power off to plug back in? Doing it powered on could cause problems.
    Also go to the Device Manager and Uninstall the RealTek - RIGHT click to highlight it and then LEFT click "Uninstall". DO NOT uninstall the drivers. Then restart the PC and when Windows starts it will detect and reinstall the sound.
