Windows 7: Help Needed. Audio Problems
03 Jun 2014   #1
Kepler
Windows 7 x64 Home Premium
Heres the problem
When i connect headphones to rear sound panel (Pink + Green)
Sound does not play out of my left speaker but mic works fine.
When i plug headset in front sound ports (Pink + Green)
Sound plays fine in both speakers but mic does not work
I use my rear sound port for the speakers on my monitor and use the front sound ports for my headset.
Uninstalled drivers and reinstalled (No luck)
Rebooted OS Fresh Install (No Luck)
Used old drivers (No Luck)
Used new drivers (No Luck)
The headset is working
Motherboard ASrock FM2A55M-HD+
Tower Case CiT 1017
Can anyone help me. ive tried everything i can think of
03 Jun 2014   #2
fireberd
Disconnect the front panel audio connector on the motherboard. Then try the rear Green speaker jack to see if you have both channels. If the sound works OK with the front panel disconnected, the problem is most likely in the front panel or connector.
03 Jun 2014   #3
Kepler
Not worked. Its not the tower. I tried the front audio ports on my old tower and still have the same problem. I know it works as it worked before. I want both speakers working on the rear of my tower and i want the mic working on the front panel. Its either a software fault or hardware fault
03 Jun 2014   #4
fireberd
Did you disconnect the front panel, as I suggested and then tried it?
What sound do you have? RealTek? or some other sound type?
03 Jun 2014   #5
Kepler
Yes i disconnected the front panel. Sound is Realtek HD Audio. downloaded the latest drivers from Asrocks website
03 Jun 2014   #6
fireberd
Try the High Definition Codec driver direct from RealTek. It will work as I have that installed on both of my desktop systems, one with a Gigabyte motherboard and the other with an ASUS motherboard.
Realtek
Also what do you have listed in the Device Manager, Sounds section?
03 Jun 2014   #7
Kepler
These are the only things in my sound
AMD High Definition Audio Device
Magic Sound (Webcam Mic) Disabled
03 Jun 2014   #8
fireberd
What is in the Device Manager is OK and would not cause your problem.
Along with the direct from RealTek drivers, check the RealTek HD Audio Manager, for setups.
Here is mine:
03 Jun 2014   #9
Kepler
Still not working. Now doesn't recognize front panel after plugging back in
03 Jun 2014   #10
fireberd
Did you get it plugged back in correctly? Its keyed but it still could be plugged in partially or wrong.
Also, did you power off and unplug it, same way power off to plug back in? Doing it powered on could cause problems.
Also go to the Device Manager and Uninstall the RealTek - RIGHT click to highlight it and then LEFT click "Uninstall". DO NOT uninstall the drivers. Then restart the PC and when Windows starts it will detect and reinstall the sound.
Help needed in HD Audio and installing Realtek drivers.
Ok so lets get started. This is my first post.Below described is my PC's rig AMD FX6300 Gigabyte GA-78LMT-USB3 Galaxy NVIDIA 630 2gb ddr3 4 gb ram and 500gb hdd my problem is that I hear only one sided audio from my headphones when I connect the HD Audio pin on the board. And when I insert...
Front Panel Audio connector help needed
So I basically have a very odd front panel audio connector setup, very confusing, I've made over 10 thread on different forums and non were able to help me. I'm using a Gigabyte G31 motherboard GIGABYTE - Motherboard - Socket 775 - GA-G31M-ES2L (rev. 1.x) Manual page for the motherboard...
Hardware & Devices
Organising Audio files - help needed
Hi guys, I've been away from WMC for a long time, but having now seen it working under W7, I was thinking about trying it again. FYI I've been using the Jriver Media Centre in the meantime. Apologies if this is basic stuff, and feel free to direct me elsewhere if necessary. So I've got loads...
Media Center
Audio drivers needed
Hi, everyone. I've recently installed Win7 on my ASUS A8V-VM-SE mobo. Win7 has found every driver except for the sound... Well, actually it has found a driver but it's showing (S/PDIF) for some reason not AC'97. I need an AC'97 driver but cannot find one that works with this mobo. I've tried...
Audio Player, Organizer Advice Needed
Hello everyone, I need an audio organizer/player that will play MP3s and WAVs, allow me to compile a list of certain songs from various sources (MP3 files, “burned” CDs), then for those songs without or with incorrect ID tag information, I need to edit the “tag”, then save (“export”) all of the...
Music, Pictures & Video
Sigmatel 97XX C-Major Audio Driver Help Needed!
I have an older P4 2.8ghz Dell Dimension 3100 that currently has Windows 7 installed. Apparently the driver is the Sigmatel 97xx C-Major audio according to support.dell.com - the first thing I tried was the Windows Vista driver listed on Dell's site. Unfortunately that did not work. The driver...
