Windows 7: Volume beeps when it reaches maximum but no audio sound on PC, Win 7
03 Jun 2014   #1
mani911
windows 7 Home Premium x32
I have a Compaq Presario PC with two operating systems: Xp and Win 7. The sound had been working fine in both operating systems up until recently when i experience zero sound from the PC. However, on Win 7 there is a beep that is perfectly audible when i slide the volume bar to maximum. I have done a couple of re-installations and double checked my audio configurations but nothing seems to be indicative of an issue. I am using an external audio device since the internal audio is non-functional. When i change the external device's PCI slot, i.e put it in another slot, it works fine then goes back to the zero audio state when computer is turned off or on standby. The drivers seem ok. Please help if you are in a position to. Thanks buddies
03 Jun 2014   #2
matts6887
Windows 7 ultimate 64-bit
to start out with something simple; sometimes completely uninstalling the device from device manager; rebooting; and then letting windows hopefully re-detect it and reinstall the drivers etc will solve the issue. Also; once you do that i would check for any driver updates which may put a permanent fix to it.
05 Jun 2014   #3
Pete4
win7hp64
If the sound stop working on both windows, I would look for common denominator and that would be hardware and BIOS. Is there anything in BIOS regarding PCI set up, IRQ etc ?
Beeps when playing audio on windows 7 x64
i just bought a used laptop, and i notice when wearing headphones that i hear a beep, i usually hear it when playing a sound. And if i pause the video i get another beep about 30 seconds after. is this a bad thing, this laptop is a dell e5420 with a i5. i dont know if i ever hear it while regular...
No audio but the green sound bar on the volume control is moving?
Hey there! A few days ago I changed my hdd because the last one got corrupted and had a lot of bad sectors so I installed a new windows 7 OS. Everything was smooth until the sound suddenly stopped. I wasn't doing anything in particular. I noticed the green bar on the volume control is moving but I...
Volume control settings: can maximum be manually overruled?
Is it possible in Windows 7 Home 64-bit to increase the native volume available for speakers. In other words elevate the volume over the defaulted maximum that comes with the software? I am having problems with the volume when I am using headsets. With all gages set to maximum volume both...
Performance & Maintenance
Soft Recording volume with Blue Yeti, increasing volume distorts audio
So I have a Blue Yeti, and I'm an online animator/voice actor. Whenever I record audio on my Blue Yeti (OR any other mic) I record about 4-6 inches from the mic, and turn the gain down enough that the audio doesn't peak as I yell or whatever. This is what you're supposed to do if you don't want...
Volume at MAXIMUM on startup
Hello all, first post here (of many probably, heh). Whenever I startup into W7 my volume is always at maximum, anyone else encountered this? I did a quick search but only founf issues related to low volume, 50% volume and sound card driver issues etc... I would love to here your thoughts on my...
