Windows 7: Need help my sound stop working how to fix?
05 Jun 2014   #1
darkherox99
windows 7 64-bit
It was working fine then just stop working some unknown reason.
05 Jun 2014   #2
fireberd
Without any System Specs, and basically "it doesn't work" we can't really do much but offer general suggestions.
Since this is apparently a recent problem, use the System Restore and restore the PC back to an available restore date when it did work. See if that fixes it.
Sound on Laptop and Desktop Randomly Stops Working and Working
So recently the sound on my desktop and my laptop has stopped working. For seemingly no reason. I really don't understand it. I first noticed it with my desktop. The sound just randomly stopped working. But not...entirely. It's really strange and complicated what's been happening, so bare with...
HDD suddenly stop working and BSOD while working
I need help please , my PC started to suddenly stop , my HDD dont even spin when i tried to touch it , the screen doesnt change , but i cant move my mouse or do anything , when i restart the pc and open the Reliability history , it says i got BSOD. i thought it was the windows before , so i...
BSOD Help and Support
Sound won't stop
Turned on my speakers only to hear a sound that wouldn't stop. It's the sound, or similar to the sound, that indicates I've turned on a device. Restart doesn't stop it. Never had this problem before. What happened, and how do I correct this problem?
USB Headset problem on W7 - Noise in sound, stop working after x mins
Good night, this problem is very annoying: I bought Logitech Headset F540, when I connect the base to my computer with USB, first I can hear a noise in the sound, then after X minutes the sound stop working. I sent an email to logitech support and they said to me that there is no problem in...
Sound card drivers show as working but still no sound
Hi, as stated in the subject, I am unable to hear any sound from my speakers since upgrading to the windows 7 64 bit. I followed the other post that I found on this but I still cannot hear any sound. I have a dell inspiron 531. The hardware ids from the device manager are ...
HDMI Sound randomly not working - test in settings gets it working?
I have started having an issue over the past week (config/drivers/etc not changed in months) where sound will randomly not be output by HDMI. System config/specs... Win7 SP1 all patches, nearly a stock install... only running WMC and XBMC. Only 3rd part stuff installed are SpeedFan an ATI...
