Windows 7: Need help enabling Realtek audio device.
08 Jun 2014   #1
igniz12
Recently I had some computer issues and had to take apart my PC and refit it back. Everything is fine now but I just realised that my Nvidia GPU is being used as the HD audio device. Audio plugs are all in the motherboard jacks and not in the gpu, my gpu dosent have any audio jacks anyway.
I didnt even realise the issue until recently when I tried to record some gameplay footage and found my recording to have screwy audio. Everything else seems to be fine as far as sound is concerned. I need to know how I can go back removing my GPU as the audio device and re-enabling Realtek. Right now I have no realtek device manager in my control panel or my programs list.
I wasnt sure if it was as simple as re-installing the drivers and rebooting the PC and I've had some major issues with drivers in the past so Im wary of trying to fix the problem on my own.
My motherboard is: Biostar TP67xe
GPU is: Nvidia gtx 570
running on win 7 home 64bit
Thank you.
08 Jun 2014   #2
fireberd
What is listed in the Device Manager, Sound section?
Post a screen shot of the Device Manager, sound section. Screenshots and Files - Upload and Post in Seven Forums
08 Jun 2014   #3
igniz12
08 Jun 2014   #4
fireberd
Two things that I see. First, the NVIDIA Virtual Audio Device is probably what is taking over your sound. Disable it in the Device Manager and then restart the PC and see if the sound works again. You may have to manually set the "Speakers" (PC sound device) as the default Audio Playback device - in the Control Panel/Hardware and Sound and finally the Sound Panel Playback section.
The second thing I see is "High Definition Audio Device". This indicates the generic, basic function, Windows installed sound driver. This will work, but the correct sound driver, Realtek in your case should be installed. Download from Biostar for your specific motherboard model and install that. TP67XE :: Motherboard :: BIOSTAR
08 Jun 2014   #5
igniz12
Alright but before I proceed, I have 2 devices in my sound control panel.
I am not using any speakers and have headphones plugged directly to my pc. Should I disable the "speakers" and use "headphones" as my default device instead in my situation?
Thank you.
08 Jun 2014   #6
Layback Bear
Windows 7 Pro. 64/SP-1
Right click on head phones and select (set as default) if you don't like it you can always change it.
I believe that is the answer fireberd would give you if he was online.
10 Jun 2014   #7
igniz12
Managed to get it running now. Made is seem like a bigger deal than I should have since it was fairly straightforward process. Thank you.
10 Jun 2014   #8
Layback Bear
Your very welcome.
Realtek HD Audio Device intalled. Still not working?
This is for a friend of mine. The computer says that there is not sound driver and has this button http://i1232.photobucket.com/albums/ff365/AmazingAura01/f_zps09026717.png because there's no sound. I don't know much of his computer but whenever we try to download and install the realtek high...
Drivers
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
no audio output device - realtek ac '97
Hello all I have Win 7 32-bit on my gateway mx6437 and am having the same problem that several people are having here - no sound. I downloaded the latest Realtek AC '97 drivers from the Realtek website. I checked to see if this card was compatible with Win 7 32-bit from the compatability website....
change audio device from realtek
hi guys i need to change my audio devise from realtek to something else (windows/other) im using windows 7 and when every i go to play a game the pc freezes ive found out that its something to do with realtek because if i disable all sound the game works fine just no sound can you tell my how to do...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
No sound from HDMI device Nvidia and Realtek HD Audio
Hi, I have installed windows 7 Ultimate 64bit and have now found I get no sound through the HDMI device. I had a simlar issue in Vista and found I had to use an older Nvidia Driver 175.97 for Geforce 7650 GS inorder to get this working with "Speaker" as default device...However in Windows 7 even...
