Windows 7: Realtek HD audio manager interface not showing advanced settings
16 Jun 2014   #11
schwarzennegger
windows 7 ultimate x64
sorry for delayed reply,i tried just now,still its the same,hearing sounds both in headphone and speaker!!!
Tried again,it worked,that just heared sound from headphone,but again got the same issue!!!
18 Jun 2014   #12
dsperber
Have you tried simply going with the ASUS-provided audio driver, from their driver support site for the G74sx? The support for the advanced features my be something that ASUS incorporated in their own Realtek audio driver installer file, that would not look the same coming from Realtek itself. Just a thought.
The audio driver from Realtek itself probably doesn't provide the ASUS-specific customizations for your laptop. For example, the Lenovo-provided Realtek audio driver for my W530 laptop includes a Dolby Surround app (including EQ, special effects, etc.) whereas I lose that Dolby app completely if I just go to the Realtek site for the driver for the Realtek chip in my W530.
The ASUS-Realtek audio driver normally proceeds as a 2-step process, the first one detecting your existing installed driver and uninstalling it, followed by an automatic re-boot. At re-boot time the installation process normally would automatically pick up again, this time doing the install itself (now that it sees you don't have an older driver currently installed). But there's a chance you may just need to manually run the installer file again after the re-boot, if the automatic-resume doesn't happen by itself.
No 2.1 Audio option in Realtek HD AUdio Manager
Deleted
Advanced Audio Settings/Controls
This isn't so much a problem as more of something I'd like to know about. I'm curious as to whether there are advanced audio controls in Windows 7 somewhere, something like XP's controls where you could control the wav and all sorts of different audio levels. Wanting to know because with earphones...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Cannot Realtek HD Audio Manager GUI/settings
After accidentally closing the HD Audio Manager from my taskbar a few days ago, my computer's audio stopped working entirely. So, after researching my problem online a bit, I checked in the Device Manager, and Realtek HD Audio was still installed as an audio driver. Taking the advice of another...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
Hello, I'm having a problem with the audio manager listed above. Because that audio manager offers things that my current one does not, I tried to install it to my computer. I went through the process, and restarted the computer as the process told me to, however I was unable to successfully...
