Windows 7: Realtek HD audio manager interface not showing advanced settings
09 Jun 2014   #1
schwarzennegger
windows 7 ultimate x64
Thank's for looking.
I have a Asus-G74sx-91234z laptop,last week when i plugged in headphone i started to hear sound coming from both headphone and the laptop speakers,a quick google search told me change some settings in Realtek HD audio manager,when i opened the user interface i found my realtek HD audio manager interface is totally different from others not having advanced setting options at all!!
I tried power of THX true studio, also installed the latest driver too,i even asked this question in asus rog forum ,nobody replied yet
G74SX- Realtek audio manager user interface NOT SHOWING ADVANCED SETTINGS!!!!
This is how my GUI looks like..
instead of the normal one like this..
Any advice much appreciated,thank's.
Realtek HD audio manager interface not showing advanced settings-presentation1.jpg
10 Jun 2014   #2
fireberd
I have never seen the second version of RealTek. I have RealTek on several PC's and they are all like the first one, however mine does have the Advanced Settings.
There are cases of some PC Vendor's limiting options within the sound. Try installing the generic driver from RealTek and see if that makes any difference. Download the High Definition Audio Codecs (drivers). Realtek
11 Jun 2014   #3
schwarzennegger
Thank you Fireberd, even though i tried installing the driver from Realtek before after reading your post i thought i give another go,this time i uninstalled the previous drivers ,restart the computer then installed the latest driver,after installing i got some surprise,i couldn't find Realtek interface at all!!! Audio is working but couldn't find the interface!!!
11 Jun 2014   #4
fireberd
Sounds Like it didn't install properly.
What do you show in the Device Manager, Sounds section?
11 Jun 2014   #5
schwarzennegger
Pls check the image
11 Jun 2014   #6
fireberd
It shows RealTek is installed. The RealTek HD Audio Manager should be in the Control Panel/Hardware and Sound.
11 Jun 2014   #7
schwarzennegger
Thank's,its there-I opened the interface,still it looks same,don't know how to short out this issue,when i plugin headphones sound coming from both laptop speakers and headphones!!
11 Jun 2014   #8
fireberd
I've seen some PC vendors remove some options (hardware) and thus its not available in the RealTek HD Audio Manager but in those cases its the opposite way - speakers mute when headset is plugged in.
Did it always work this way, or did it previously mute the speakers when you plugged in headset?
11 Jun 2014   #9
schwarzennegger
It was fine before,happened recently,as far as my knowledge i didn't install new software!!!
Sound coming from both speakers and headphone [Solved]
the above link they have a solution for this issue,i couldn't do this bcoz i don't have that option at all in my interface.
11 Jun 2014   #10
fireberd
For testing, uninstall RealTek and delete the drivers. Then restart the PC and Windows will install the generic, basic function, HD Audio Codec sound driver. See if it works properly (speakers mute when you plug in headset) with this driver.
No 2.1 Audio option in Realtek HD AUdio Manager
Deleted
Advanced Audio Settings/Controls
This isn't so much a problem as more of something I'd like to know about. I'm curious as to whether there are advanced audio controls in Windows 7 somewhere, something like XP's controls where you could control the wav and all sorts of different audio levels. Wanting to know because with earphones...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Cannot Realtek HD Audio Manager GUI/settings
After accidentally closing the HD Audio Manager from my taskbar a few days ago, my computer's audio stopped working entirely. So, after researching my problem online a bit, I checked in the Device Manager, and Realtek HD Audio was still installed as an audio driver. Taking the advice of another...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
Hello, I'm having a problem with the audio manager listed above. Because that audio manager offers things that my current one does not, I tried to install it to my computer. I went through the process, and restarted the computer as the process told me to, however I was unable to successfully...
