Windows 7: I am missing my audio device, need help please...
10 Jun 2014   #1
jacal78
Hello friends,
I am new here so all the help that I can get would be really appreciated. I have a HP Pavilion p7-1380t system with IDT High Definition Audio Codec driver for it. For some reason I cannot get it to work at all. I have tried everything, updating from HP website, from HP Recovery Manager. I really need this sound. I am working on a project that requires sound and I don't have one.
Any input is greatly appreciated, thank you...
jacal78
10 Jun 2014   #2
fireberd
Please post a screen shot of the Device Manager, Sound section and the Sound Panel, Playback section.
11 Jun 2014   #3
jacal78
Screen shot of Device manager and Sound Panel
11 Jun 2014   #4
fireberd
The Sound/Playback section is what is needed. The "Speakers" (IDT) should be set as default playback device.
11 Jun 2014   #5
jacal78
Is this what you want sir...
11 Jun 2014   #6
fireberd
Yes. Now, RIGHT click on an empty area in that Playback Panel and then Click to show Disabled and Disconnected Devices. Does the "Speakers" (IDT) now show up?
11 Jun 2014   #7
jacal78
No sir doesn't show anything at all...
11 Jun 2014   #8
fireberd
Try uninstall/reinstall of the IDT. In the Device Manager, RIGHT click on the entry for the IDT and then LEFT click "UNINSTALL". DO NOT check the box to also uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the IDT. If there was a Windows corruption this will fix it.
HDMI Audio Device No Longer Appears as Playback Device
I was wondering if you could give me some advice on a current computer issue. So, I've got my TV hooked up to my PC as an extra monitor via HDMI. Up until last night I was able to get audio from my PC to be played/heard/whatever through the TV. Earlier in the evening, I saw a bunch of...
not plugegd in onboard audio device after disconnecting external audio
I have an Echo Audiofire4 firewire device, for some reasons I need to constantly switch between Echo and my onboard audio device (realtech sth). I remember I could do it in the past, but due to the Echo installation problems I disabled it from windows startup menu and now, though I enabled it...
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
base system device, video controller and unknown device missing
hie i have just installed window 7 and this devices are missing, any help will be very much appreciated. base system device device id PCI\VEN_1217&DEV_7110&SUBSYS_117C10&PEV_00 PCI\VEN_1217&DEV_7110&SUBSYS_117C10CF PCI\VEN_1217&DEV_7110&CC_088000 PCI\VEN_1217&DEV_7110&CC_0880 UNKNOWN...
Drivers
C-Media AC97 Audio Device. This device cannot start.
C-Media AC97 Audio Device. This device cannot start. (Code 10). Sound hardware on ASUS Mobo will not work after installing Windows 7. Latest drivers installed. Don't know what else to try?
Drivers
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
