Windows 7: Sound not playing through headphone jack
19 Jun 2014   #11
jinzu
Yes, it is still working in Linux. I will have to probably reinstall Windows. Even system restore doesn't help it.
Off topic but is Windows 8/8/1.x better than Windows 7? I am using Windows 7 because Windows 8 looks like it is optimized for touch screen PC.
Thank you for looking at this post.
19 Jun 2014   #12
fireberd
I didn't want to suggest a "clean" reinstall (reformat and install).
Both sides to Win 8.1. Some hate it and others do not. I have it installed as a dual boot. I also have "Start8" which makes Win 8 work and look just like Windows 7. However, if I want I can use the "Metro" which is the Tiled screens.
I have a recording studio and all my recording hardware and software (Sonar X3) runs equally on both Win 7 and Win 8/8.1 (with the Start8).
19 Jun 2014   #13
jinzu
Should I just back up my Windows partition and install again? Not a clean install but as in deleting Windows partition, not reformatting, and then only installing Windows over that free space? Or should I just back up files and programs, then install Windows only and add in my files again?
19 Jun 2014   #14
fireberd
In most cases a "clean" install should be done. Backup your user data first. Programs will have to be reinstalled.
I don't know how the partitioning works on a dual boot system with Linux. Windows 7, on a clean/new install to a hard drive installs two partitions, a "System Reserved" and the NTFS partition.
19 Jun 2014   #15
jinzu
I will do this. Should this topic be marked as solved? The problem was not fixed but can be fixed through a clean install.
19 Jun 2014   #16
fireberd
That should fix it (hopefully) but don't mark it solved until you are sure.
Headphone jack light?
I have a red light in my headphone jack when I'm using windows 8 but then when I get back onto Windows 7 (dual boot) the light doesn't turn on. Does anyone know how I could turn it on? Toshiba A500
Hardware & Devices
Front Headphone jack..
Hi guys i m new here... need some help. My front headphone jack is not working but mic is working.. Headphone works properly at rear jack. System info. System model - PI945GCM Processor Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz, 2670 Mhz, 2 Core(s), 2 Logical Processor(s)...
No Sound From Front Headphone Jack
Hi, When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500. The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't....
Got sound from my headphone jack abut nothing from speakers
I have a ASUS laptop running win 7 64 bit. out of the blue the sound stopped working. no sound will come from the internal speakers, though sound is being registered in the various volume control screens. If i plug speakers into my headphone input, the sound comes out. IVe tried all the various...
Headphone Jack Problem - Help!
Hello All, my sound output on my laptop (the headphone jack...) is broken, almost certainly a hardware fault, I've tried pretty much everything I know of within windows to no avail. It's only outputting to the right. So, is there any way to configure windows so that it recognises my line-in or...
Hardware & Devices
Sound through headphone jack, but not laptop speakers
I usually listen to music with speakers through the headphone jack. When I unplug the speakers, the music plays through the stock laptop speakers like it is supposed to do. However, all of a sudden, the sound has only worked through these external speakers. It plays fine through the headphone...
