Sound not playing through headphone jack
  1. Posts : 13
    Hello,
    I am running Windows 7 x64 on an Asus U56E machine. The audio works fine on my Linux partition through both the speakers and headphone jack. The headphone jack therefore works.
    But I cannot get sound using working headphones while listening through the headphone jack in Windows 7.
    How to fix this?
    Welcome to the Windows 7 Forum.
    Researching that model (you failed to fully fill out the "My System Specs") you have RealTek audio.
    Do you have the RealTek sound driver installed? Here is the link to the ASUS drivers ASUSTeK Computer Inc. -Support- Drivers and Download U56E
    Can you post a screen shot of the Control Panel/Hardware and Sound, Sound Panel Playback and the Device Manager Sound sections.
    This will give us something to start with. Since it works in Linux that says the hardware is OK.
  3. Posts : 13
    Hello,
    Yes, I have the latest sound driver from Asus website.
    Here are the screenshots.
    Attached Thumbnails Attached Thumbnails Sound not playing through headphone jack-control_panel.jpg   Sound not playing through headphone jack-device_manager.png   Sound not playing through headphone jack-sound_panel.png
  4. Posts : 8,135
    I wonder4 if the DFX is causing the problem. Are there any setup options for this that could affect the headphone jack? If not, temporarily disable the DFX in the Device Manager, then restart the PC and the "Speakers" should be set as default playback device and then see if the headphone jack will work.
  5. Posts : 13
    I have disabled the dfx enhancer in my device manager. Yet, the audio still is not played through the audio jack.
    When playing music, the volume mixer shows sound playing. It can be heard through laptop speakers but not the headphones.
  6. Posts : 8,135
    Did you restart the PC after disabling? If not, give that a try.
    Otherwise, try uninstalling the RealTek in the Device Manager (DO NOT uninstall the drivers) then restart the PC. If there were any Windows corruption in the RealTek this will fix it.
    Did this ever work OK?
  7. Posts : 13
    I disabled and restarted but it did not resolve the problem.
    I uninstalled the Realtek, not drivers, and restarted but the problem persists.
    The sound worked one month ago.
    This problem has occurred before but I was able to fix it by uninstalling the Realtek and restarting my PC, but I cannot get it to work now.
  8. Posts : 8,135
    Disable the DFX then Uninstall the RealTek AND the drivers and then restart. Windows will install the generic HD Audio Codec sound drivers. See if this works.
    If the headphone jack works OK with the generic HD Audio Codec drivers, try installing the RealTek drivers direct from RealTek and see if that works. Realtek
  9. Posts : 13
    I disabled DFX, uninstalled Realtek and the drivers. The sound drivers were installed as High Definition Audio Device instead of Realtek. But the problem remains. I can hear the audio through speakers but not the audio jack.
  10. Posts : 8,135
    Ouch! If its still working OK in Linux, it has to be something in the OS. I don't have any info on any tweaks that can be made to correct this. I'm at a loss.
