Windows 7: Sound not playing through headphone jack
18 Jun 2014   #1
jinzu
Hello,
I am running Windows 7 x64 on an Asus U56E machine. The audio works fine on my Linux partition through both the speakers and headphone jack. The headphone jack therefore works.
But I cannot get sound using working headphones while listening through the headphone jack in Windows 7.
How to fix this?
18 Jun 2014   #2
fireberd
Welcome to the Windows 7 Forum.
Researching that model (you failed to fully fill out the "My System Specs") you have RealTek audio.
Do you have the RealTek sound driver installed? Here is the link to the ASUS drivers ASUSTeK Computer Inc. -Support- Drivers and Download U56E
Can you post a screen shot of the Control Panel/Hardware and Sound, Sound Panel Playback and the Device Manager Sound sections.
This will give us something to start with. Since it works in Linux that says the hardware is OK.
18 Jun 2014   #3
jinzu
Hello,
Yes, I have the latest sound driver from Asus website.
Here are the screenshots.
Sound not playing through headphone jack-control_panel.jpg   Sound not playing through headphone jack-device_manager.png
18 Jun 2014   #4
fireberd
I wonder4 if the DFX is causing the problem. Are there any setup options for this that could affect the headphone jack? If not, temporarily disable the DFX in the Device Manager, then restart the PC and the "Speakers" should be set as default playback device and then see if the headphone jack will work.
18 Jun 2014   #5
jinzu
I have disabled the dfx enhancer in my device manager. Yet, the audio still is not played through the audio jack.
When playing music, the volume mixer shows sound playing. It can be heard through laptop speakers but not the headphones.
19 Jun 2014   #6
fireberd
Did you restart the PC after disabling? If not, give that a try.
Otherwise, try uninstalling the RealTek in the Device Manager (DO NOT uninstall the drivers) then restart the PC. If there were any Windows corruption in the RealTek this will fix it.
Did this ever work OK?
19 Jun 2014   #7
jinzu
I disabled and restarted but it did not resolve the problem.
I uninstalled the Realtek, not drivers, and restarted but the problem persists.
The sound worked one month ago.
This problem has occurred before but I was able to fix it by uninstalling the Realtek and restarting my PC, but I cannot get it to work now.
19 Jun 2014   #8
fireberd
Disable the DFX then Uninstall the RealTek AND the drivers and then restart. Windows will install the generic HD Audio Codec sound drivers. See if this works.
If the headphone jack works OK with the generic HD Audio Codec drivers, try installing the RealTek drivers direct from RealTek and see if that works. Realtek
19 Jun 2014   #9
jinzu
I disabled DFX, uninstalled Realtek and the drivers. The sound drivers were installed as High Definition Audio Device instead of Realtek. But the problem remains. I can hear the audio through speakers but not the audio jack.
19 Jun 2014   #10
fireberd
Ouch! If its still working OK in Linux, it has to be something in the OS. I don't have any info on any tweaks that can be made to correct this. I'm at a loss.
Headphone jack light?
I have a red light in my headphone jack when I'm using windows 8 but then when I get back onto Windows 7 (dual boot) the light doesn't turn on. Does anyone know how I could turn it on? Toshiba A500
Hardware & Devices
Front Headphone jack..
Hi guys i m new here... need some help. My front headphone jack is not working but mic is working.. Headphone works properly at rear jack. System info. System model - PI945GCM Processor Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz, 2670 Mhz, 2 Core(s), 2 Logical Processor(s)...
No Sound From Front Headphone Jack
Hi, When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500. The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't....
Got sound from my headphone jack abut nothing from speakers
I have a ASUS laptop running win 7 64 bit. out of the blue the sound stopped working. no sound will come from the internal speakers, though sound is being registered in the various volume control screens. If i plug speakers into my headphone input, the sound comes out. IVe tried all the various...
Headphone Jack Problem - Help!
Hello All, my sound output on my laptop (the headphone jack...) is broken, almost certainly a hardware fault, I've tried pretty much everything I know of within windows to no avail. It's only outputting to the right. So, is there any way to configure windows so that it recognises my line-in or...
Hardware & Devices
Sound through headphone jack, but not laptop speakers
I usually listen to music with speakers through the headphone jack. When I unplug the speakers, the music plays through the stock laptop speakers like it is supposed to do. However, all of a sudden, the sound has only worked through these external speakers. It plays fine through the headphone...
