Windows 7: H.D. Audio not work??
29 Oct 2009   #1
Ujji12
Windows 7 32bit ultimate
Guys I'v been searching and reading and pulling my hair out for 3days!!
I had Windows XP, then installed Windows 7 32bit Ultimate on IDE hard drive.
HOW DO I GET SOUND??
The desktop on Windows 7 shows icon on bottom right hand corner of speaker. It has a red X next to it.
The Troubleshooting thing completes:
Problems found
High Definition Audio Device has a driver problem Not Fixed X
Reinstall device driver Completed
Check audio device Detected !
There might be a problem with your audio device
When I go to Device Manager it shows:
Sound, video and game controllers
! High Definition Audio Device
Also shows in System devices it shows:
High Definition Audio Controller
I have installed many drivers from many sources but to no avail.
29 Oct 2009   #2
torrentg
7600.20510 x86
1) You already did clean install. Nothing more to be concerned with.
2) try Windows Update. If nothing, right click it in device manager, properties, details tab. Change dropdown to hardware ids. Copy and paste the results to a post here.
30 Oct 2009   #3
Ujji12
This is what it came up with
HDAUDIO\FUNC_01&VEN_434D&DEV_4980&SUBSYS_00010083&REV_0900
Oh and in the Generals tab it says:
This device cannot start. (Code 10)
30 Oct 2009   #4
torrentg
7600.20510 x86
You could try the C-Media XP driver for your board. Install using the device manager. Right click the audio device, update driver software, browse, let me pick, have disk, browse. Find the .inf now.
30 Oct 2009   #5
Ujji12
OK the X on the speaker thing is gone....also when i play musc the visulisation seems to pick up the signals
But no sound yet?
When i right click the speaker icon, sound, playback, i have selected speakers as my default as it shows visulisation.
I also have 'digital output' underneath with the same device name and is labelled 'ready'.
30 Oct 2009   #6
Sleerts
Windows 7 Pro 64 Bit
Welcome to my hell. I have a Vostro 200, came with Windows Vista on it, and my audio card WILL not detect that I have my speakers plugged in. My computer passed the "Can you upgrade" but unless I went to Dell and checked to make sure my model was able to upgrade...F DELL!!
31 Oct 2009   #7
Ujji12
YES!!......I unistalled all the drivers i installed prior to your help. Now i got sound baby Yeah. Thank You TORRENTG Also i found how to load drivers so that i can do format and fresh install.
Sleerts you should try to do what i was told:
31 Oct 2009   #8
voltron
windows build 7600
Quote   Quote: Originally Posted by torrentg View Post
PCI\VEN_1106&DEV_3288&SUBSYS_08881849&REV_10
PCI\VEN_1106&DEV_3288&CC_040300
how about me? same problem any suggestions?
31 Oct 2009   #9
torrentg
7600.20510 x86
Quote   Quote: Originally Posted by voltron View Post
Not sure. I really couldn't find too much on it so I attempted something for you with a slight chance of success.
Install by using the device manager. Right click on device, update driver software, browse, let me pick, have disk, browse. Find the .inf in the XP folder where you extracted to.
Good luck!
31 Oct 2009   #10
voltron
windows build 7600
Good luck!
what .inf file am I looking for?
HDMI audio doens't work on TV
I tried to attach my tv to an old PC, so I could play movies from my computer. THe video works, but the audio doesn't. I used a HDMI cable, got realtek driver, enabled and put HDMI as standard output. But no sound. The GPU of this computer is Nvidia gt8400. If you need any intel I can provide you...
HDMI Audio output - how to get it to work???
I only have this problem with 7, so I know it is not a hardware related issue. I simply can not get any sound out of my graphics card (seemingly) through HDMI. I have my bios setup to play audio from it. I've followed what everyone else has done when using the search, I have zero success. ...
My audio doesn't work on Windows 7 64 bit !
Hi guys, I just formated my PC which had Windows 7 32 bit and intsalled Windows 7 64 bit. The problem is that everything works great except my audio. I installed the latest drivers from Intel's website but to no avail. I even tried downloading it from Realtek but also it didn't work. You see I was...
Trying to get my audio to work!
i installed 7 on this older pc i have that was made with some different parts. im trying to get audio on this but i havnt had any luck. here is the pcs specs. windows7 32bit p4 2.4ghz 512ram and here is the motherboard info:
For the life of me i cannot get audio to work
Hey all I hope someone can help. I have read a lot on the forums but have not come across my particular problem Here is my system Processor (CPU) AMD ATHLON™ 64 X2 7750+ (2.7GHz) 2 x 512K L2 Cache (Socket AM2) Memory (RAM) 2GB CORSAIR DOMINATOR 1066MHz Motherboard ASUS® M3N78: DUAL DDR2,...
Any experience with Audio work? (DAW's, etc)
Hey all, just wondering, if anyone has some experience working on some popular Audio Applications on Windows 7? Like, Ableton live 7, some Native Instruments plugins, MIDI controllers, and other 3rd party plugins. That's what I own, so I'd love to start from there. But, any experience is...
Software
