Windows 7: Realtek High Def Audio, Mic not working in frontpanel, rear grayed out
29 Jun 2014   #1
fernandosinsoni
Windows 7 64 bits Ultimate
Hi
I changed motherboard, for ASrock 960GV-GS FX, and installed windows 7.
Problem:
Rear audio panel not working, if I plug a headset, I don't hear sound, mic is not recongnized.
If I plug in front panel, I hear LOW sound, mic not recongnized.
Mic just doesnt move any green bar, nor generates audible sound in windows recorder.
Rear panel (analogic) is always grayed out no matter what.
In audio properties I can pick front panel, but microphone is like dead (works ok in other pc).
Bios: tried enabling both front and rear, and variations like: just one of 2, both in "auto" and so on. Nothing improves.
Drivers: tested several, I'm using those provided with motherboard.
Motherboard connections: everything looks good, tried, even disconnecting front panel, and using jumpers on audio, but even in that case I can't get the rear panel active.
Finally I activated all kind of devices to see if I can make some work, looks like this:
Volume tested.
help!!!!
30 Jun 2014   #2
ICIT2LOL
Hello and welcome Fernando is this the driver you are using for the board
ASRock > N68C-GS FX (second down from top) ? and you might even need to dothe chipset driver too
If you are then maybe the board has a fault mate.
The other suggestion I would make but it would only give you the back panel option is a sound card I use the Asus Xonar DG and it ha a very good GUI for mixing and such. Sound Cards and Digital-to-Analog Converters - Xonar DG - ASUS
30 Jun 2014   #3
fernandosinsoni
Hello and thanks for reply!
NOPE, that's not my motherboard model page, so I'm not using those you posted really...
I'm using the one listed here ASRock > 960GC-GS FX
that's for ASUS 960GC-GS FX, whose download es 170.55 mb, Windows® 7 64bit
Why do you ask? Do you have a reason for me to change to those you mention or what?
And What you mean by "and you might even need to dothe chipset driver too"
Does that mean that I need ANOTHER DRIVER IM MISSING ?
Your last solution is to install another audio card and forget about the one in mobo right?
01 Jul 2014   #4
ICIT2LOL
Sorry for late reply mate and that was a mistake on my part I copied and pasted that first number and came up with the ref I sent how it did that I have no idea. So the drivers are the ones you have listed.
The chipset was just a suggestion if the audio driver did not fix the problem as it is the control between the CPU and the rest of the machine see this for a fair explanation
Motherboard Chipset
Yes I am a bit of an audiophile myself and like to have good quality audio and one that I can control the effects and mixing etc. The card itself is cheap enough and so easy to fit but again it is a personal choice.
Realtek HD Audio/Creative Xtreme Soundcard No rear speakers.
To start, Hi, I am a first time poster to sevenforums, and registered here because of the wealth of information threaded out over the years. Well done to all. Right now down to the serious :). I, as many others have experienced the sadness of upgrading to Windows 7, only to find that my 5.1 rear...
Realtek HD Audio No Rear Sound
I have a problem with the Realtek HD Audio. I just installed Windows 7, and configured my audio settings for all my 4 speakers, 2 front and 2 rear. The test was successful, from Realtek HD Audio Manager. But I was just playing a song on iTunes and there was no sound coming from the rear speakers....
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
Realtek HDMI+NVIDIA = no sound+frezze screen using pc rear audio jack
Hi every one i am new at this i might carry on please forgive me if that happens. i am having this Realtek HDMI+NVIDIA =No Sound issue + if i connect back to my rear audio jack with my speakers its fine to listen music but it freeze the screen during game play and gives out a loud buzz sound than...
Realtek HD Audio Manager ''Mute Rear Speakers'' HELP
Hey, For quite a while now i've been using a pair of USB Speakers. I had it set so my games came out my speakers and my Team speak Voice chat came through my headset. I recently decided to swap back to my Creative speakers, but now i have an issue. When i plug my speakers and headphones in...
Realtek HD Audio Non Working Rear Speakers
Hello Everyone , I recently searching in forums to get solved my problem , but no one fix that issue . I Read many threads so i need the fix because i'm sick to see another posts from fools that they don't know anything about software's or hardware's. So My Problem Is : Yesterday i format...
