Problem With Sound Blaster LIVE CT4830
  1. Posts : 4
    Windows XP
    Hey People!
    Am having problem with my Sound blaster live audio card, tried to install a dozen of drivers not sure why it's not working either..done according to compatibility mode and etc but it's not working any body got any idea how i can go about working this, like how i should be exactly doing this because this is quite frustrating if i have to replace this sound card for a really expensive upgrade which is unnecessary
    Hope u can help
  2. Posts : 5,747
    7600.20510 x86
    Old hardware by a company notorious for bad drivers. Time to move on and find a real audio solution.
    If you think about it, your pc really only does 2 things for the most part. It shows you video and it lets you hear sound.
    Get a new, decent audio card that at least is marketed as being compatible with Windows Vista.
    I have no idea if this is compatible driver that 7 will work with. You could try though.
    http://drivers.softpedia.com/progDow...nload-549.html
  3. Posts : 4
    Windows XP
    what kinda sound card do u reccomend that supports windows 7
  4. Posts : 5,747
    7600.20510 x86
    You would do really well with something like this.
    Sabrent USB-SND8 8-Channel USB 2.0 External 7.1 Sound Box at TigerDirect.com
    I can recommend more expensive solutions or internal ones if you want. But this seems fairly decent and good value for the price.
  5. Posts : 6,879
    Win 7 Ultimate x64
    Only hope for that old card (like 10+ years old) is #4 here,
    Creative Sound Cards.
    Make sure you uninstall/cleanup everything you have tried installing before.
    Be that as it may, you show me any hardware company that is providing Windows 7 support for something that came out 10+ years ago.
  6. Posts : 1
    Windows 7 Ultimate (x64)
    bheng said:
    Hey People!
    Hope u can help
    I have a spare Sound Blaster Live! audio card and will test it in my system and try to come to some conclusion for you if that would help? :)
