Windows 7: Problem With Sound Blaster LIVE CT4830
30 Oct 2009   #1
bheng
Windows XP
Hey People!
Am having problem with my Sound blaster live audio card, tried to install a dozen of drivers not sure why it's not working either..done according to compatibility mode and etc but it's not working any body got any idea how i can go about working this, like how i should be exactly doing this because this is quite frustrating if i have to replace this sound card for a really expensive upgrade which is unnecessary
Hope u can help
30 Oct 2009   #2
torrentg
7600.20510 x86
Old hardware by a company notorious for bad drivers. Time to move on and find a real audio solution.
If you think about it, your pc really only does 2 things for the most part. It shows you video and it lets you hear sound.
Get a new, decent audio card that at least is marketed as being compatible with Windows Vista.
I have no idea if this is compatible driver that 7 will work with. You could try though.
http://drivers.softpedia.com/progDow...nload-549.html
30 Oct 2009   #3
bheng
Windows XP
what kinda sound card do u reccomend that supports windows 7
30 Oct 2009   #4
torrentg
7600.20510 x86
You would do really well with something like this.
Sabrent USB-SND8 8-Channel USB 2.0 External 7.1 Sound Box at TigerDirect.com
I can recommend more expensive solutions or internal ones if you want. But this seems fairly decent and good value for the price.
30 Oct 2009   #5
stormy13
Microsoft MVP
Win 7 Ultimate x64
Only hope for that old card (like 10+ years old) is #4 here,
Creative Sound Cards.
Make sure you uninstall/cleanup everything you have tried installing before.
Be that as it may, you show me any hardware company that is providing Windows 7 support for something that came out 10+ years ago.
05 Nov 2009   #6
jonbreen
Windows 7 Ultimate (x64)
Quote   Quote: Originally Posted by bheng View Post
Hey People!
Hope u can help
I have a spare Sound Blaster Live! audio card and will test it in my system and try to come to some conclusion for you if that would help?
Sound blaster Live! Value card - no sound
Done the research, and unless I've missed something, there's a caveat that hasn't been addressed in this issue. I have an SB Live! value card, have installed the Daniel_K driver for it, following the suggestions about deleting the existing RealTek (which didn't seem to work, though I didn't put...
Creative Sound Blaster 5.1 live
Hi hope someone can help i am very new to this forum, at this moment i running XP Pro I want going to upgrade To Win 7 but it not recognise my Creative Soundblaster 5.1 sound card which is working fine under XP with all that i use i have been on web site to try & find driver for it. someone posted...
Problem with Sound Blaster! Live 5.1 on Windows 7 x86
Hi dudes Could anyone help me to find the correct driver for my soundcard?, it is a Creative SB Live! 5.1 It was working fine on WinXP, but since I changed the OS to W7 its sounds is terrible. I have tried to install many of those mod drivers , but everytime the following error message...
Sound blaster live!
The right drivers at the last post: http://www.sevenforums.com/sound-audio/79428-sound-blaster-live.html#post694541
Sound Blaster live
Please help. I have installed Win 7, but when I want to install Sound Blaster live software, it says that no sound card is installed. I installed the kx software and the sound works, but I cannot use my midi keyboard and somehow my micr0phone will not work in Skype. I would realy like my...
Hardware & Devices
Sound Blaster 5.1 Live!
hi at everybody. i'm new on this forum... yesterday i've installed windows 7 on my desktop pc, but i've some problems with audio card : model -> Creative Sound Blaster Live! 5.1 where i can find correct drivers for this audio card??? thanks a lot
Drivers
