Windows 7: Mic not working in front or rear panel.
06 Nov 2009   #11
Parker
Windows 7 x64 Ultimate
Any chance someone knows how to fix this problem?
30 Oct 2010   #12
dhym
i am having problem same as Parker can anyone help me please, i did bios AC97 too still i am having that problem. please anyone know cure let me know.
31 Oct 2010   #13
dhym
i found cure here is the link ASUS Motherboard : World’s 1st MB to Obtain WHQL Certification !
download audio driver according your motherboard CD.-enjoy all-
Front Usb Panel Not Working.
Sir, Motherboard - Asus P5g41t-MLX Last week i changed my cpu cabinet. Done the installation. But, after installation, i have some problem with the cabinet's front usb ports & audio ports. The motherboard have 4 usb ports & 3 audio ports (rose,green.blue) at the back side. All these are working...
Hardware & Devices
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Front Panel on both builds not working
The Bios has already set up HD on Audio I put in the Front Panel on the right slot Also the Cd with the drivers are installed Help please? Thanks! Only the Front Panel Audio Is not working Motherboard is Z87-A Antec Case http://www.memoryexpress.com/Products/MX37559
Front Panel audio not working correctly
When I plug-in my headphones into the front panel jack, the audio will only emit from the left speaker. I haven't tried re-seating my sound card, don't know if it's necessary. Is there anything other than analog output (Xonar DX Audio Center) that I have to change in order for it to work correctly?...
front panel headphones not working
I have a Gigabyte GA-P55M-UD2 mobo and realtek HD Audio installed on my computer which is a Win 7 64-bit Home premium prior to all this i had a major computer update i think it was close to 70MB or so, downloaded and installed it restarted computer, everything was working fine 2 days ago...
mic not working on front panel
Hi I bought my wife a new pc as the old one was a single processor and very slow. It has 2 issues. The new one seemed straight forward, quad core much faster but two issues are annoying enough to make my wife not want it. 1. The front panel seems to be wired differently to the old pc - my...
