Realtek HD problem with Windows 7
  1. Posts : 1
    Windows 7 Professional
    Hi everyone!
    Well, i´m a bit sad with my situation.
    I just got from my university (MSDN) a copy of Win 7 Pro and I installed it in my notebook. But now i got a problem with my sound device.
    When i used the sound driver that came with the fresh install of the windows i got some noises with the souns i was listening. Then downloaded the newest version of the driver (Vista_Win7_R236) from the realtek website. But the noise went worse!
    I tried a lot o things to solve the thinks, like turning off the PC Beep, unistalling the driver and installing again, etc, but I´m still getting this friggin´ noise!
    I relly donpt want do go back to Vista.
    Well, I hope that someone can help me!
    Well, thanks folks!
    CyA.
  2. Posts : 8
    Windows 7 Professional 32bit
    is the noise really loud
  3. Posts : 16
    W7 Prem 64 on Dell, Home Build W7 Pro 64 1drv, XP Pro 1 drv
    Try turning off mic when not in use and see if this helps.
  4. Posts : 8
    hey mathiah i have found a solution.
    Uninstall realtek HD driver for windows 7 and download the vista driver
    here is the link HD AC 97 Driver Version R2.14 for Windows Vista 32/64-bit
    i hope this helps.:)
