Windows 7: No Sound Boost Bar Extremely Low Mic Sound
08 Jul 2014   #1
MarshCaptain
I have no boost bar in the mic settings. I have no idea why. The worst part is that Windows 7 is making my mic ultra quiet. Its pretty much in my mouth. How do I fix it? The Mic works great on my Mac and consoles but on my Windows 7 PC the mic volume is ultra low.
08 Jul 2014   #2
fireberd
You haven't listed what sound you have, such as RealTek, Connexant, etc. You can find out what sound drivers are installed in the Device Manager, Sounds section. If only "High Definiton Audio Codec" is listed for the sound, that indicates the generic, basic function, Windows installed sound driver and not the actual sound driver for the sound chip. If you can't find out what sound chip you have, check Samsung for your specific PC (and drivers).
Some sound drivers, such as RealTek include a Sound Panel and that may have some sound enhancement that will help if there is no mic boost. Not all PC's have the mic boost.
08 Jul 2014   #3
MarshCaptain
It says Realtek HD. Windows is starting to suck more and more. All I want is louder mic volume. Its fine anywhere else its just ultra quiet on this PC. I know its not the mic. Is there an external mic boost option? Its been disabled on this PC.
08 Jul 2014   #4
fireberd
Its not Windows 7, the majority of users like and prefer Win 7 over Vista and Windows 8 and even XP users like Windows 7. Your problem is either the Drivers and/or what the PC vendor has allowed. Off chance the mic jack has a bad connection somewhere. I assume this is a laptop and not a desktop. One thing to check, the "Ring" connection should have +5VDC on it, as that is what is needed for computer microphones. Low voltage can lead to problems. On a standard 3.5mm Stereo Plug, the Tip is the signal, the ring is the +5VDC and the sleeve is ground.
You can try the RealTek drivers directly from RealTek and see if that helps. Download and install the 64 bit version High Definition Audio Codecs. Realtek
FWIW, I do a lot of audio work as I have a recording studio (and am an ex guitar amp tech).
12 Jul 2014   #5
MarshCaptain
Any other program has my mic high and everyone can hear me. When I run a voice recording through Windows its unbelievably low. So low I cannot hear me very well on playback. Now tell me if its a problem with my Mic or Relatek or whatever this is. I need help. Point me in the direction of an external volume booster or something which will help. This is driving me nuts.
I tried installing Realtek drivers, boosting audio with recording software and everything is turned up to max. This is only an issue with With Windows 7.
12 Jul 2014   #6
fireberd
Did this PC have something other than Windows 7 initially? As I noted initially, not all PC's have the mic boost feature.
Also, did you measure the voltage on the "ring" connection to see if its actually 5VDC or something less? Something less can cause low computer microphone volume.
If you are trying to use a standard P.A. type mic, the output level is very low and needs boosted up BEFORE the PC.
A preamp MAY work, but the preamp needs to be able to provide the 5VDC for the computer mic.
12 Jul 2014   #7
MarshCaptain
I checked everything and its all good. The PC came with Windows 7.
Headphones plugged to speakers,extremely low sound.
I have plugged the headphones to my speakers but the sound is extremely low. I have tried different headphones it is the same low sound. These headphones in other devices work perfect. The speakers also work perfect.What is the problem?Any suggestions? I have a desktop Microsoft Windows 7...
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound jumping from normal volume, to extremely low.
So for the past few days, whilst watching youtube or playing a video game, I have noticed that my computer's sound has bounced from normal volume to extremely low. Nothing seems to effect it, as it does it randomly. I have changed out wires, and speakers (I only have my center speaker hooked up...
Microphone boost without any background sound
Hello SF.I have Realtek HD Audio Manager and I hate that it boosts up my microphone and it gets a strange background noise(something like a "fsssssss").Hope you can help me....
Bass boost breaks sound and causes it to be robotic
Hello, I am new to this forum due to a bug with my bass boost. I had some problems earlier with my gigabyte GA-990FXA-UD3, Socket-AM3+ and my Tiamat subwoofer not working. Uninstalled Realtek and Dolby to get it working again. Now i have some bass atleast,eventhough i would like to have some...
Extremely low sound from earphones...Help!
I have a XFX nForce 680i LT SLI board with onboard Hi-Def. Using Win7 Ultimate 32bit. I use my Blackberry earphones plugged into the back panel green jack. Never had any problems with this setup until about a week back. A week ago, without ANY apparent reason (no new programs/drivers...
