Windows 7: Is there any way to permanently lock the mic volume level?
10 Jul 2014   #11
WebMaximus
Having Task Manager trigger on a microphone volume event
I posted about a microphone volume issue I've been having over in the audio sub-forum where the microphone volume is set to different values automatically by different programs and I was hoping there would have been a way to permanently lock the microphone volume so that can't happen. Turns out there's no way doing that so now I found a command line utility instead called nircmd which can be used to set the microphone volume in a very fast and silent way using some switches.
Now my next mission is how and when to trigger this command which will set the mic volume back to the level I like. I was thinking of using Task Manager and I could of course set it to run the command to set the mic volume every 5 minutes for example. However that could mean I would be recording at some other level without knowing about it for up to 5 minutes until the task is executed again.
For this reason I checked Task Manager and found I can choose to use a trigger called 'On an event' rather than 'On a schedule' and I was thinking maybe that's what I'm looking for...? However I'm not sure what exactly to use if it's even possible to have Task Manager monitor the mic volume. Ideally I would like Task Manager to run my command whenever the mic volume is set to anything but the value I want in my case 75%.
Does anyone know if this is possible or maybe you have some other smart ideas...?
10 Jul 2014   #12
carwiz
Windows 7 Pro-x64
Are you using Realtek drivers? If you are, turn Exclusive Mode off. (Both check boxes.)
10 Jul 2014   #13
WebMaximus
No, I have my mic connected to an external Asus Xonar U7 sound card.
However I already unchecked the exclusive options but to no avail.
10 Jul 2014   #14
WebMaximus
Need some help NirCmd
Just found a very powerful command line tool that let you do pretty much everything you could ask for.
I'm trying to use this tool to set my microphone volume and just setting the volume one single time works just fine but I want this to happen repeatedly making sure my mic volume is always at the same level where I want it.
The command to do this using NirCmd looks like this
nircmd setvolume 1 49500 49500 (this will set the volume to 75%)
Doing the same thing but repeatedly I should be able to use the loop switch like this
nircmd loop 5 1000 setvolume 1 49500 49500 (this should do the same thing 5 times every 1000 milliseconds)
For some reason this doesn't work. Looking at the nircmd process in Task Manager I can see how the loop command works because nircmd stays in the processes list in Task Manager for 5 seconds. However the volume is only set once and if I change the volume manually during these 5 seconds it should be returned to 75% every 1000 milliseconds but it's not.
Just to make sure the loop switch works I tried the exact same line as above but I replaced the setvolume command with another nircmd command sending a 'beep' to my speakers and sure enough I heard the beep loud and clear 5 times in a row every 1000 milliseconds. The command looked like this
nircmd loop 5 1000 beep 1500 1000 (where 1500 is the Hz and 1000 is the length of the beep)
So...I can't see why the setvolume command can't be repeated the same way.
Any experienced nircmd user in here who could help me understand what I'm missing here?
17 Jul 2014   #15
n8n8baby
I am having a similar problem using 'win activate' within a loop. 'speak text XXX' works fine within the loop.
Volume level keeps resetting to 30%
I'm at the end of my rope with my volume issue. I'm running Win 7 64 Pro with a Creative X-FI Gamer card (latest drivers). The issue: Master volume keeps resetting to 30%. Noticed it happens when I bring my PC out of standby, and when I run certain apps like Creative's sound panel. I've tried...
Volume level continuously changes
I have been struggling with trying to find a fix for this for a long time now. I have searched various forums and tried the couple suggestions that seemed to be offered for similar issues but nothing has worked. I have no other serious issues with W7 but this is REALLY annoying and making me want...
USB Condenser Mic Recording Volume Level
Hi guys, basically I have purchased a behringer c-1u, of course before I did some research and there were issues with the volume. Now that I have it, I have the same issue that many people with the mic also have, and that is with the volume it records at. In the windows sound mixer the...
NVIDIA Audio Deck volume permanently at zero
I have a custom built PC from a local computer shop, Ipurchased it just over a year ago. Last night I tried to play some music through iTunes but got no sound. I tried the headphone socket and tried a USB set of headphones, still no sound. When I go to the Audio Deck or the mixer the sliders...
permanently lock taskbar and start menu
Is there a way to permanently lock items on the task bar and start menu? I can for example lock the taskbar, but can still drag icons onto or from it and rearrange them. I want to lock everything permanantly so no one can screw them up. I'm using Home Premium.
General Discussion
How to Change volume level only with mousewheel
To change the volume level on Linux just put the little arrow-click on the audio icon on the taskbar and use the mouse wheel without having to click. This is possible in Windows Seven, changing some configuration in the system?
