Is there any way to permanently lock the mic volume level?
As the topic suggests, is there any way to permanently lock the mic volume level so no applications no nothing but me myself can change it?
Reason I ask is for some reason my microphone volume level keeps resetting by itself. I like to have it at about 75% but all of a sudden it has dropped to 18% making my voice barely audible in audio recordings and sometimes I find it at 100% making my voice too loud.
I already did some Google searching and looks like this problem is very common and usually caused by applications such as Skype etc automatically adjusting the mic volume level. In my case I'm not running any of those "normal" applications but instead I'm running some special addon applications for Microsoft Flight Simulator X. My guess is one or a few of these are causing my issue but since I need these applications I can't solve the problem by getting rid of them. Instead I need to find a way to "lock" the mic volume if that is possible?
Any help would be most appreciated!
Guess I should also mention I'm running Windows 7 Ultimate 64-bit.
Many thanks in advance!
