Windows 7: Is there any way to permanently lock the mic volume level?
09 Jul 2014   #1
WebMaximus
As the topic suggests, is there any way to permanently lock the mic volume level so no applications no nothing but me myself can change it?
Reason I ask is for some reason my microphone volume level keeps resetting by itself. I like to have it at about 75% but all of a sudden it has dropped to 18% making my voice barely audible in audio recordings and sometimes I find it at 100% making my voice too loud.
I already did some Google searching and looks like this problem is very common and usually caused by applications such as Skype etc automatically adjusting the mic volume level. In my case I'm not running any of those "normal" applications but instead I'm running some special addon applications for Microsoft Flight Simulator X. My guess is one or a few of these are causing my issue but since I need these applications I can't solve the problem by getting rid of them. Instead I need to find a way to "lock" the mic volume if that is possible?
Any help would be most appreciated!
Guess I should also mention I'm running Windows 7 Ultimate 64-bit.
Many thanks in advance!
09 Jul 2014   #2
fireberd
Programs are supposed to return the audio levels to what they were when you exit the program. Unfortunately many programs don't do that and leave the audio levels where they were in that program. In the case of "back acting" programs, if there are audio setups in the program you could set the mic level for what you want and then when you exit those "bad acting" programs it wouldn't change and be at the level you want.
Another possibility is a utility program that you could run and reset the levels to what you want. I saw reference to a utility recently on here. I'll try to find it and post back.
The thread is in the Windows8 forum. Here: http://www.eightforums.com/sound-aud...lume-boot.html It is for a set volume level at boot, but as its just a utility, it could be run anytime.
09 Jul 2014   #3
WebMaximus
I read somewhere about a tool too that would set the mic volume constantly to a level of your choice. A little bit annoying having to have a program running in the background only to keep the mic volume where you want it but maybe that's the only way. However I'm not sure where I read about it and can't find it anymore so if you find it that would be great.
I wish there was a way locking the mic volume in such a way that it would override everything else. Maybe via some registry hack or a policy.
09 Jul 2014   #4
carwiz
Windows 7 Pro-x64
Check the software you use. I don't use it but I think Skype has an option for auto volume/mic. Turn it off.
10 Jul 2014   #5
WebMaximus
Thanks but as I wrote in my first post I'm not using any of those programs known to mess with the mic volume and the programs I'm running that might mess with the mic volume are all needed so I guess rather than trying to find a way for any program to not mess with my mic volume I instead if possible need to find a way to lock the volume.
10 Jul 2014   #6
fireberd
There is no way, that I'm aware of, to "lock" the volume. If that were the case then any program that uses audio would not be able to change it, if needed - and setting the volume for a given application is used by many programs.
As I originally noted, programs, if they are programmed correctly, will restore the audio levels to where they were when exiting the program. Poorly coded (programmed) programs will not do this. Thus users are stuck with audio levels that were set by the program after exiting the program.
Thus the only option is to have a utility program that you can run and reset the audio levels to what you want.
I can't do that with my recording studio equipment, either.
10 Jul 2014   #7
WebMaximus
Ok, guess I'll have to find that tool again that would constantly reset the mic volume if I only could remember where I saw that.
Thanks anyway for trying to help.
10 Jul 2014   #8
fireberd
Click on the link in my original post.
10 Jul 2014   #9
WebMaximus
Sorry, missed that link.
However the tool I found somewhere (but haven't been able to find again after all different forums I visited the last couple of days...) would run in the background and constantly setting the volume level several times each second making sure it will always be at the desired level.
Looking at the tool linked in your post after some quick reading it appears to only set the volume once and then you need to run the script again manually. Guess I could use Task Manager to schedule it to run as often as I like. Also I'm not sure if this tool will be able to set the mic volume, the discussion over in that other thread is about setting the speaker volume.
Will try searching a bit more for that first tool I read about somewhere but thanks anyway
10 Jul 2014   #10
WebMaximus
Finally I was able to find the post where I read about that tool/utility, here it is for anyone else interested
When using my microphone, the microphone level automatically adjusts. - Microsoft Community
Volume level keeps resetting to 30%
I'm at the end of my rope with my volume issue. I'm running Win 7 64 Pro with a Creative X-FI Gamer card (latest drivers). The issue: Master volume keeps resetting to 30%. Noticed it happens when I bring my PC out of standby, and when I run certain apps like Creative's sound panel. I've tried...
Volume level continuously changes
I have been struggling with trying to find a fix for this for a long time now. I have searched various forums and tried the couple suggestions that seemed to be offered for similar issues but nothing has worked. I have no other serious issues with W7 but this is REALLY annoying and making me want...
USB Condenser Mic Recording Volume Level
Hi guys, basically I have purchased a behringer c-1u, of course before I did some research and there were issues with the volume. Now that I have it, I have the same issue that many people with the mic also have, and that is with the volume it records at. In the windows sound mixer the...
NVIDIA Audio Deck volume permanently at zero
I have a custom built PC from a local computer shop, Ipurchased it just over a year ago. Last night I tried to play some music through iTunes but got no sound. I tried the headphone socket and tried a USB set of headphones, still no sound. When I go to the Audio Deck or the mixer the sliders...
permanently lock taskbar and start menu
Is there a way to permanently lock items on the task bar and start menu? I can for example lock the taskbar, but can still drag icons onto or from it and rearrange them. I want to lock everything permanantly so no one can screw them up. I'm using Home Premium.
General Discussion
How to Change volume level only with mousewheel
To change the volume level on Linux just put the little arrow-click on the audio icon on the taskbar and use the mouse wheel without having to click. This is possible in Windows Seven, changing some configuration in the system?
