Windows 7: Sound works, but not 'reacting' in Volume Mixer?
09 Jul 2014   #1
Terrum
Windows 8.1 Pro with Media Center
So I have a strange issue where software will perform fine without any issues; the sound works fine and there's no issues whatsoever with that. However when I look at my Volume Mixer, it shows the program as normal but no activity in sound. So when sound is actually playing, the green meter doesn't react. This has also made sound impossible to stream or record (such as when trying to screen record a game with Fraps for example because it can't detect the sound). I've made sure the sound card I'm using is set to default and all others are disabled (such as the onboard one) and that everything is setup properly (otherwise I wouldn't be able to hear it!)
Sound card is an ASUS Xonar DX and I'm running Windows 8.1 (I couldn't sign up to Eight Forums for some reason, just kept redirecting me to the login page). Any help is appreciated!
09 Jul 2014   #2
Terrum
Managed to fix this. It was an issue in Xonar's DX Audio Center. I disabled GX which fixed it. Apparently GX is some sort of game sound enhancer? Which ironically didn't enhance anything Either way hope this helps anyone who has the same issue!
10 Jul 2014   #3
fireberd
Please mark this Solved.
Unknown Sound Volume Mixer
Svchost.exe virus I've been on 4chan /g/ and they sent me here. I'm not to sure on what this is, the application I've narrowed it down to is svchost.exe. This thing plays sounds, songs, advertisements; kinda like someone is rotating through an AM radio station. I've tried my best to remove...
System Security
Windows 7 Volume Mixer not showing all sound applications
The Volume Mixer in Windows 7 is supposed to show applications that are running sound, right? Well, mine shows some applications, like Firefox and Guild Wars 2 and Mozilla Thunderbird and KMPlayer. But it doesn't show volume for other applications that use sound like Winamp and ePSXe (playstation...
Volume Mixer problems
Hello, For some reason when I turn the system volume to 0, other programs do not also go down to zero. In the volume mixer, when master volume is at full, other programs are at full too, and when I move the master volume slider down, the other sliders go down too... However when master...
Volume Mixer issue
I have this huge problem with my volume mixer. I re-sat my TF2 volume to about 24, and now i want it up again, but guess what happens... Every time i then close TF2 or even pick an other server, it re-sets itself back to 24. Please help since i am a sound geek.
Volume mixer issue / sound control
Hello guys, I searched the forum for common problems but unfortunately I could not find any useful information for this issue. I hope you can assist me as the Windows 7 volume mixer is freaking me out and I cant seem to find a way out with this... I run Windows 7 on a Dell Inspiron 6400...
Volume Mixer lost IE sound...
So when you click the sound icon in the tray and then Mixer usually IE, Windows Media Player, and any other application that uses sound shows up, but now IE is missing there... does anyone know what could have caused this?
