Windows 7: No audio but the green sound bar on the volume control is moving?
12 Jul 2014   #11
ShaioF
Windows 8 64 bit
Help
Hey my name is Shaio Fencski, I'm 13 years old and know alot about computers. The only reason a sound system would not be working is either it is sending it to another speaker that is virtual and just keeps switching or that your computer power options are turning the sound driver off, yes of course the volume moves but it moves even when a sound driver is not installed, all systems come with a sound system and all of them can be disabled, I would try to get a sound splitter and plug one end into a surround sound system or bom box or somthing, and the other end into headphones or ear buds. if both of them create sound then your computer and drivers are fine, if only 1 or none of them make sound then there is somthing really wrong with the computer, and I would suggest getting a new one.
13 Jul 2014   #12
theneves
Windows 7 Home Premium 32-bit
Click run and enter "services.msc" without qoutes. Look for Windows Audio. At the left side, click Start if it is Stop, otherwise click Restart. Hope this help. Post back if it solved your problem.
-Jethro.
13 Jul 2014   #13
Zziko0
Windows 7 Ultimate 64 bit
Quote   Quote: Originally Posted by theneves View Post
-Jethro.
Today it happened again - the sound went off and I tried that method. I opened services.msc and it said "Started" so I restarted it and it worked. What does that mean?
13 Jul 2014   #14
theneves
I can't figure out the rason yet. I'll try to examine it.
But you can do this:
Go to services.msc again. Double click Windows Audio. Please check if the Startup Type is set to Automatic. If not, please change it. Then restart the PC/Laptop. Check if it occurs again.
-Jethro.
13 Jul 2014   #15
Zziko0
-Jethro.
Yes it is set on automatic. One more thing - I have Windows audio endpoint builder. I have no idea what it is since I am nowhere near good on OS architecture. Should I check something on it too?
14 Jul 2014   #16
Zziko0
Just installed a brand new windows copy. Went well for 2 hours and the EXACT same problem. I was not doing anything in particular. I didn't even run windows updates just in case but the problem is here again. Why is this happening... I just don't get it.
15 Jul 2014   #17
Zziko0
Guys please I am desperate and I spent $100 on a HDD a few days ago for this laptop.. I don't want to buy a new one as the " 13 year old guy who knows a lot about computers" said..
P.S. The restart thing that theneves told me to use is working for about 10-20 seconds now.
23 Jul 2014   #18
theneves
Did you consider the suggestions above - by fireberd and ShaioF?
I guess the problem is your hardware. I think it is the cause of the problem, since you said that you installed a new copy of your Windows. I am not very knowledgeable when it comes to hardware. I guess someone here can help.
-Jethro
sound volume control problem in WMC
Hi, I have only one small problem with the sound volume control in WMC. I have a new HTPC, pumpimg sound out via a Digital coax cable to Logitec z5500 speakers. This works just fine, sounds great etc, except..... The sound volume control in WMC doe not work when watching Live TV, or TV accessed...
Media Center
Volume Control wont move sound card slider
I have E-MU 1212M sound card, Windows 7 and I can't fix this problem which I haven't had before. I reinstalled the Windows 7 and now I can't move my Volume Control and affect my sound card volume. My sound card volume wont move until I move it. It's like my volume mixer is pre-effected,before my...
Setting up 5.1 surround sound using only red and green audio jack.
Hi guys, I was wondering how I would do a 5.1 surround sound set up using only the microphone jack and headphone jack on my laptop - without utilizing an external sound card. What I am interested in is: would it be possible to reconfigure/reassign the role of each audio port and how...
Green Bar in Volume Control is Moving, No Sound
I have speakers plugged in to my computer running Windows 7 Home Premium 64Bit. The computer is recognizing that I have speakers plugged in and when I play something the green bar moves with the music. However, no sound is coming from the speakers. I have gone into the BIOS settings and enabled...
Sound unmuting when I touch volume control?
Is there anyway I can disable the sound unmuting when i turn the volume control knob? Vista didn't do this and it's really annoying as its on the bottom so i always catch it when the laptop is on my lap.
Volume mixer issue / sound control
Hello guys, I searched the forum for common problems but unfortunately I could not find any useful information for this issue. I hope you can assist me as the Windows 7 volume mixer is freaking me out and I cant seem to find a way out with this... I run Windows 7 on a Dell Inspiron 6400...
