Windows 7: No Sound via HDMI on monitor speakers??!!!!?!!
11 Jul 2014   #1
hahapapalala
Windows 7 64bit Ultimate
Hello guys, I bought a new monitor from LG and connected it via HDMI to my laptop but the sound does not work on the speakers of my monitor could you help me please???
11 Jul 2014   #2
HarriePateman
Windows 7 Ultimate 64-bit
Set it as Default Device, and Disable the Intel device. Then restart.
11 Jul 2014   #3
hahapapalala
It is already set as default. Isn't the intel device responsible for the sound via hdmi??
11 Jul 2014   #4
fireberd
Maybe its a problem or setup issue in the LG Monitor?
11 Jul 2014   #5
hahapapalala
I have got a windows 8 partition on my laptop and on win8 everything works fine
11 Jul 2014   #6
carwiz
Windows 7 Pro-x64
Right click on your desktop and select Screen Resolution. Does that screen show both displays? If not, click on Detect. Does it show now?
HDMI monitor no speakers-no sound from anywhere when connected?
I have an external monitor with no speakers I use as a dual display along with my laptop monitor. No sound comes out of my laptop speakers nor when I hook up external speakers to it while I have the external monitor hooked up by the HDMI cable. Is there anything I can do to get this to work?...
Sound from HDMI and pc speakers at the same time
Hi guys! I've been struggling with this problem since I got my computer, a little over a year ago. I've tried everything, but can't figure out how to get sounds from my pc speakers and HDMI at the same time. It's really annoying having to change the primary output multiple times a day (I...
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
No audio through monitor speakers via HDMI
I purchased a new monitor and it looks great but I can't get the built-in speakers to function. The monitor has inputs for VGA, DVI, and HDMI and I currently have it connected to my video card via HDMI. The front panel audio jack is functioning and I am able to hear audio if I plug headphones in...
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
Monitor Speakers not working when connected via HDMI to laptop
Hi, I've recently purchased a Samsung T23A750 monitor and to my disappointment when I try to watch a movie the built in speakers are not functioning. I have a Sony Vaio Z216GX connected via HDMI to the monitor (HDMI-DVI) port. I can definitely see the video, but no audio is playing from the...
