Windows 7: Need external sound card
13 Nov 2009   #11
Microsoft MVP
Win 7 Ultimate x64
Can't really help with what does and doesn't work with the 2 NX as I have never had or used one, for the most part everything is guess work on what works with other cards. As to the Audigy 4 that I can do.
You shouldn't need the EAX Console but instead assuming it installed (and it should as it gets installed with the driver) you can make those settings in the Audio Console,
That is from Vista (haven't gotten around to moving that computer to 7 yet), but it should give you an idea what to look for.
14 Nov 2009   #12
Joy!!! Audigy 4 has rear speaker sound!!
I've been searching the web...talking to teckies and have even been to the Oracle of Delphi twice looking for a way to get sound out of ALL my speakers, not just the LF and LR in my 5.1 setup. I thought I had narrowed the problem down after reading about the problem and solutions on the Creative support page. Still, I was frustrated because whe instructions for all speaker sound required the installation of the EAX console which apparently is not installed (at least not on my machine after 3 re-installs) with the Audigy 4 disk/web update on my Windows 7 64 bit system. Quiet frankly I was ready to ditch Windows 7 due to the speaker problem and a persistent system problem I have with Windows Explorer periodically stopping.
And then your suggestion on where I should look. Great...I do have an EAX function in my Creative Audio of the places I had not explored.
I just didn't know EAX selections for the environment of the computer (or at least the audio effects I was trying to immolate) were controlled by selecting an EAX condition: small room, Auditorium, etc.
Now to the good part....following the instructions in your last post, I have found the EAX function now and have sound on all speakers. Gold stars to you!! Now if I could just solve that pesky "Windows Explorer Stopping" problem, I might even keep Windows 7.
Thanks again Stormy. You know your S@#$
Search this Thread:
Advanced Search
No audio through external sound card on web only
I have a Acer with Windows 7 Ultimate x64 and my headphone jack is broken. When i want to listen to music or any audio on the web the sound plays through my laptop speakers. I have the vms2 audio midi device configured as my default player. All other audio including traktor plays audio through my...
Does anyone have advice for using an external sound card?
I was thinking of trying one to see if the sound garbling problem I experience would be alleviated with an external sound card.
External Powered 5.1 Sound Card
Anyone know of an external sound card, usb or hdmi, that supports surround sound and has a built in amplifier. I have passive speakers. I've been looking all over google but can't seem to find one that I can afford. I'm looking for something cheap, very cheap, like less than 100. I looked into the...
External Sound Card out of sync
Hi everyone! I'm using an external Creative X-Fi SoundBlaster soundcard and after the 2nd day using it, it started playing the sound from my laptop abt 0.2secs late. Anyone knows what I could do to fix this? Thx
Using an External Sound card
Hello all, as my internal laptop sound card doesn't support SPDIF out - i've decided to go with an external sound card and through the external sound card - hook it to my receiver for 5.1/7.1 sound. My question is how is it that i would connect my external sound card to my receiver. Say i was to...
Looking to buy a new external/usb sound card
Hello 7forums, My onboard soundcard isn't working with win7. I really like the performance win7 is giving me for everything, from games (no sound), to processor-heavy loads, but I just can't get the audio to work. I have tried a lot of sound drivers listed in these forums, but they all say the...
