Windows 7: Low System Volume with Altec Lansing BXR1121 speakers
15 Jul 2014   #1
sikm
windows7
I've just re-loaded Win7 and all is well - except. The system sound is very low - all other sounds are okay - I've done everything that I can think of, updated software checked the adjustment for communications, adjusted everything I can think of.
I seem to recall that I had this problem last time I re-loaded windows but, of course, I never documented it, think it had something to do with the actual speakers.
Anyone help?
15 Jul 2014   #2
Vuxy
Hello Sikm,
Thank you for notifying us of your problem.
Is you think it's a problem with your speakers, can you try plugging them into another computer and see if it works?
If it works fine in another computer, it's a problem with your computer and we'll have to resolve it.
Thank you,
VinnyBuxton
15 Jul 2014   #3
sikm
windows7
Not the speakers
Hi Vinny. No the speakers are fine, were okay b4 I re-installed Windows, work okay on other systems and, except for one respect, work perfectly well on this PC.
The problem is either software or system settings I feel sure. You can google many threads which have a similar problem but there is no clear resolution.
I've got the latest drivers, I've tested - via the speakers option at bottom right - the speakers and the test sounds fine, I've checked the communications tab in the speaker configuration but nothing that I do boosts the system sounds.
This morning I even uninstalled the audio (Realtek) that came with the m/b thinking there might be a clash but still no difference.
Not having system sounds ain't life threatening but it's bloody annoying.
16 Jul 2014   #4
Vuxy
Hello Sikm,
Are you able to uninstall the speaker driver and then re-install it from your manufacture's website?
1. Click start menu and type in Device Manager.
2. Expand Sound, video and came controllers and right-click the listed sound driver.
3. Select uninstall and follow the on-screen instructions.
Thank you,
VinnyBuxton
16 Jul 2014   #5
sikm
windows7
i'd already done that....
....Vinny. I've uninstalled the realtech drivers and re-installed the latest, no difference, Currently running with the Win7 drivers and all works well......except system sounds! I seem to think that the fix last time might have had something to do with some codecs I downloaded?
16 Jul 2014   #6
Vuxy
Hello Sikm,
The best suggestion I can give you is to chat with Realtek - Realtek
Thank you,
VinnyBuxton
16 Jul 2014   #7
fireberd
First, what do you show in the Device Manager, Sounds section? You should ONLY have the RealTek and possibly an HDMI audio entry (if you have HDMI). If you have any "HD Audio Codec" entries, that indicates generic Windows installed sound drivers (either for the PC sound or HDMI sound). If you have any HD Audio Codec entries, uninstall them in the Device Manager and restart Windows. Check the Device Manager, Sound section after the reboot to see what you have.
Best option would be to post a screenshot of that Device Manager section.
16 Jul 2014   #8
sikm
windows7
Solved!
After all it WAS something very simple.
I downloaded the latest version of Realtek HD Audio Drivers and installed it - again. Then, using the Realtek Audio Manager I selected speakers and the Sound Effects tab. On that page there is a check box that you could easily miss labelled 'Loudness Equalization', check the box and Lo, system sounds are now as they should be.
Thanks for all the help guys.
external altec lansing speakers keep making high Pitched Noise
I bought this speakers a while ago for my older computer and recently i bought this new hp so im using them on my new hp desktop and ever since i bought the speakers they have allways made this high pitched noise .Now my HDD makes the same high pitched noise but not as loud as my speakers make it i...
Altec Lansing in-built Speakers not working?
Okay. In my HP-Pavilion dv5000 (dv5201) it has Altec Lansing speakers, and I can't find any drivers. I had to clean install 7 because my sister isn't smart, and installed Mandriva over XP. I don't even know it's model, because Win7 doesn't recognise it. I installed all but the language updates,...
Drivers for Altec Lansing ACS595 speakers
Still got my old Altec Lansings from the last millenium. They still sound awesome. I bargained with Dell when I bought my first ever PC and they upgraded the speakers to get the sale. So glad I managed to squeeze that one last deal out of them, these speakers sound great and have served me well...
Music, Pictures & Video
Speaker system question-Altec Lansing ADA995
I have a 5.1 speaker system connected to either my PC via the green/yellow/black leads or to my cable box via an RCA to 5.1 Logitech adapter to use the speakers. I understand that the adapter doesn't make the sound from the cable box true 5.1, that's fine. The issue is that to switch from the PC...
mic on altec lansing
i have an Altec Lansing 2.1 vs2421 speaker system. it comes with a built-in mic. how do i hook it up? isn't there supposed to be a pinkish cord to plug into the mic jack?
Problem with Altec Lansing MX5021 Subwoofer
I have an Altec Lansing 2.1 speaker system. (MX5021 90W RMS output, 30Hz - 22KHz audio range). It has been fine for more than 3 years, but presently I am having some problems with it. After power up, the speaker is almost okay. But very low volume growling noise (i.e. random sound of low...
