Windows 7: No sound on Sound Blaster X-Fi Xtreme audio
20 Jul 2014   #11
marioeres
Windows 7 Ultimate x64 Service Pack 1/Windows 8.1 with WMC x64/Windows 8.1 with WMC x64
OK,thanks for reply.
Can you provide any link, program, troubleshooting, or whatever else, in order to check for hardware failures, other than those offered on the Creative site, (which are so general, and pretty much time savvy, but not extensive enough) ?
Looking forward.
20 Jul 2014   #12
fireberd
I assume you have the correct speaker system selected (stereo, 5.1, etc) and the SoundBlaster speaker (analog) set as default playback device. Those are the only two Windows things that could cause the problem.
I don't know of any computer program for troubleshooting. But, Windows is showing its working, the green bar is moving, etc, but there is no output. That sounds like a potential hardware problem in the SoundBlaster.
One thing, if you can talk your friend into installing it in his system, to test, that would tell you if it is or isn't working.
Sound Blaster X-Fi Xtreme Audio: Speakers pop when I click some things
I put in a Creative Sound Blaster X-Fi Xtreme Audio (PCIe), installed the latest driver from Creative, found here: Creative Worldwide Support (1.04.0000, released 30th June, 2009), and it seems that whenever I click things that make noise (a good example being the volume slider in the system tray),...
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
Hey mates, Today I bought and installed a new sound card. Creative's Sound Blaster X-Fi Xtreme Audio PCI Express. More information about the card can be found here: Creative Labs Online Store (Europe) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio Anyway, this card is a...
Sound Blaster X-Fi Xtreme Audio 70SB104000001
Hi guys I treated myself to a new pc but the only thing missing is a soundcard. Im looking at Sound Blaster X-Fi Xtreme Audio 70SB104000001 Creative Labs Online Store (UK) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio I am running windows seven home premium 64bit and i...
Sound Blaster X-Fi Xtreme Audio / Creative.com
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Hi, im running windows 7 (7100) 32 bit. Ive got Creative Sound Blaster X-Fi Xtreme Audio in, ive downloaded the xp, vista and 7 beta drivers from creative, they either say driver version not found OR they say the device isnt plugged in properly, which it is having run it with xp. The only thing i...
