No sound on Sound Blaster X-Fi Xtreme audio
Hello guys,
Last night I was helping to a friend and connected his computer with mine by KVM switch. We had done all, I got unplugged KVM switch,reconnected my monitor,KB an mouse.Everything was just fine.
After a while,without reason, (or there may be some reason which I can't figure out),I just got lost out of my sound. Uninstalled and reinstalled all X-Fi apps,no good.
Now I have installed a fresh OS,updated (it's all accurate under my system specs),and all drivers,including SB X-Fi Xtreme audio.No good.
1.Device Manager recognizes proprely under Sound, video and game controllers (SB X-Fi Xtreme Audio/This device is working properly.)
2.Click on Speakers icon,on the General tab,Jack Information :No Jack Information Available
3.Check or uncheck box next to Digital output settings makes no difference
4.Headphones tested on another computer,working
5.Equalizer shows moving green line when playing audio,as if it work
6.No system sounds
7.There are 2 events in Event Viwer,attached to this post.
I have fresh Windows 7 Ultimate SP1 x64,no antivirus,no antimalware,no any other program,only updates, Adobe Flash Player,and drivers.
Starting to think that i'm missing something simple.Totally confused here after checking so many things so many times.
Looking forward to your response.
