Microphone voice recording low, but "hits" and humming high
  1. Posts : 21
    7 pro x64
    It's a nice paradox my microphone.. i'm on a asus k52ju + win7x64
    After several complains from a few friends i tried to fix the microphone recording, and here are the results:
    I've heard the micro myself using the following option
    and my voice is too low or barely audible, but if i it the laptop with 1 finger, or do any kind of drumming (for example typing on the keyboard) it's audible as hell.
    What could be wrong with it? It does pretty much the opposite of what it should
    Here are some settings that might help:
    Edit: also the drivers are updated, (always have been), and increasing the microphone volume only agravates the problem
    What microphone are you using? Brand and model?
  3. Posts : 21
    7 pro x64
    conexant smart audio hd? it came embed on the laptop
  4. Posts : 8,135
    But, the actual microphone? e.g. the built in the PC mic, or some other that you are connecting using the mic jack on the PC.
  5. Posts : 21
    7 pro x64
  6. Posts : 8,135
    I assume by your response, that its the Mic built into the PC. Is this correct?
    Has it ever worked? as it sounds like a defective mic. Is this PC still under warranty? If it is contact ASUS about the problem and suspected defective mic.
    Do you have an external Computer Mic that you can try?
