Windows 7: Default Audio Device Problem
02 Feb 2009   #1
Windows 7 Build 7000
Hi guys, Windows 7 is having trouble saving my default audio device. Every time I assign it, hit OK, and restart it changes from what I set it to. So every restart I have no sound and I have to manually change the playback defaults and it works fine until I restart again.
This what it looks like when I change it and hit OK
And this is what changes after every restart
Any idea of a cure for this?
02 Feb 2009   #2
Appelhülsen Germany
Hi Smokozuna,
Welcome to the forum.
After setting it up try right clicking and disabling all the devices that you do not need
02 Feb 2009   #3
I just tried it and unfortunately it did not work. I am open to more suggestions. The communication device that I am trying to get to default is a Magickjack USB phone device and the default device are my desktop speakers if that helps.
02 Feb 2009   #4
Appelhülsen Germany
Yes, no wonder that it is always going back to the USB speakers.
Where are your normal speakers plugged in?
Have you tried disabling the normal speakers and configuring the USB ones?
Do you get any sound at all from the USB speakers?
02 Feb 2009   #5
Windows 7 Build 7048 x64
Hi smokozuna and welcome to the forum!
Have you tried reinstalling the driver for MagicJack?
If you haven't, unstall, restart, install, restart if required, set as default then restart.
02 Feb 2009   #6
Quote   Quote: Originally Posted by pooch View Post
Where are your normal speakers plugged in? audio jack in back of PC
Have you tried disabling the normal speakers and configuring the USB ones? no, I do not have any usb speakers
Do you get any sound at all from the USB speakers? I do not have usb speakers
answers in quote
02 Feb 2009   #7
Quote   Quote: Originally Posted by NosferatuX View Post
Just tried it but no luck, I think this is a driver issue because with the magicjack plugged in my bios hangs for several seconds which it has never done before.
02 Feb 2009   #8
Appelhülsen Germany
Yes it looks like a conflict to me as well, I take it that the normal audio drivers are installed and that everything works when the Magic Jack is removed
02 Feb 2009   #9
First, Thank You very much guys for the quick responses, I Really appreciate it!
Yes, when Magicjack is removed everything is swell and when I initally set up Magicjack per these instructions for Windows 7 everything is swell but when I restart all bets are off.
Thirty5tech - Windows 7 Beta
My BIOS hangs for several seconds, my audio devices reassign themselves, some times I get a no audio error.
02 Feb 2009   #10
Hi smokozuna,
Please check this out. It provides some interesting information and additional USB information and explanation on why you're encountering your issues. You might also want to see this.
Cheers!
 Default Audio Device Problem problems?
Similar help and support threads for: Default Audio Device Problem
audio device isn't set as default, can't make it default Sound & Audio
Solved Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox Sound & Audio
Problem selecting Default Audio Device Sound & Audio
Default audio device in VM issue Virtualization
Audio device reverts to default. Sound & Audio
