Windows 7: Trouble getting sound to speakers W7 Pro 32 bit??
08 Aug 2014   #11
carwiz
Windows 7 Pro-x64
What happened when you clicked Yes in the above message? Where are USB, Mic and Headphone jacks located that you show separate from the PC output panel?
Also, does the Nvidia Console show any sound properties? You may have some type of driver conflict. What does the VIA Control Console look like?
Change your Volume Control Options and check only "All devices currently playing sound". Uncheck all other boxes in that window.
Trouble getting sound to speakers W7 Pro 32 bit??-volumn-control-options.jpg
The volume bar shows sound but no sound through speakers.
Hi, I am pretty stumped with this one. I upgraded my office to windows 7 32bit pro. 10 computers all the same, but one of them has audio issues. When I play the sample music the volume bar shows the equalizer bouncing like it is sending out audio, but any speakers I plug into it produce no...
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
Speakers; No Sound
No sound through speakers that were used with Pavillion 7955 being replaced with HP Pavillion p7-1154; No problems with speakers, still work with pc taken out of service. Unable to resolve problem, have gone through Troubleshooter, updated drivers, and other suggested fixes-nothing has worked. Any...
No sound from speakers but showing sound graph on speaker control
I have an MSI 785GTM-E45 Mother Board. I have no sound coming from the speakers. Tried new speakers and still no sound. If I click on the speaker Icon on the bottom right it shows the speaker graph going up and down as sound is being produced. I tried the head phones and nothing coming from them...
No sound from built in speakers, but sound from headphones
I have a Lenovo S10-3 Netbook, running on Win7 starter. It has been running fine unil a few days ago, when the built in speakers no longer play any sound. Works fine with earphones or exernal speakers, but not internal speakers. Drivers are all up to date, and audio/sound settings are all...
