Windows 7: Trouble getting sound to speakers W7 Pro 32 bit??
02 Aug 2014   #1
klxdrt
w7 pro 32 bit w/XP virt enabled.
I have been trying every combination to get speakers (sound) from my W& Pro 32 bit PC with Nivda sound card. If you guys need more details, I can supply screen shots of what I tried.
I have a set of USB speakers with a single lite green RCA jack and these work. How do I set them up?
I'm not a techie, but an experienced user but this has me stumped. So please be clear.
cheers,
klx.
02 Aug 2014   #2
carwiz
Windows 7 Pro-x64
Some model numbers might help to identify your hardware/accessories. Your specs say no sound card. ???
What "Nivda" sound card? Is the "sound card" internal or external? Did you load any drivers for the sound card?
What USB speakers?
02 Aug 2014   #3
klxdrt
I knew this wasn't going to be simple??
carwiz
Thanks much for your quick response. I will get back with more info, busy in sveral other projects so it will be next wk. I was able to get the tiny speakers in my monitor working so I'm ok until then.
cheers,
klx
05 Aug 2014   #4
klxdrt
Carwiz,
To answer your orig questions, drivers were loaded when I installed the sound card 1 1/2 yr ago and was able to get sound until recently.
As promised, I published a 1 pg web with with screen shots & additional commentary of my sound problem that should answer all your questions at: sound problem
Look forward to hearing from you and anyone on this forum with a solution.
cheers
klx
05 Aug 2014   #5
carwiz
Windows 7 Pro-x64
Please use this method for posting images to the Forum. The link below is a tutorial.
05 Aug 2014   #6
klxdrt
W7 sound config problem images.
Currently, I am able to get sound thru my monitor's tiny speakers with only a HDMI cord to the monitor.
I want to be able to get sound thru the small stereo but I'm not sure of how to set it up? Something tells me that the current HDMI connection overrides any other independent sound connection to the stereo receiver.
I have tried many combos to no avail.
Below images are all specs, etc. about my PC's sound setup that I could find so you guys would have plenty info. Hope this helps.
Sorry the images are not in any order even though they were numbered. Also, built a well organized web page but this forum suggested I use this method.
cheers
klx
Trouble getting sound to speakers W7 Pro 32 bit??-1video-card-specs.jpg   Trouble getting sound to speakers W7 Pro 32 bit??-10c-pc-front-output-stereo.jpg   Trouble getting sound to speakers W7 Pro 32 bit??-12c-speakers-usb-front.jpg   Trouble getting sound to speakers W7 Pro 32 bit??-13d-stereo-front.jpg   Trouble getting sound to speakers W7 Pro 32 bit??-14d-stereo-back.jpg
Trouble getting sound to speakers W7 Pro 32 bit??-2sound-cards.jpg Trouble getting sound to speakers W7 Pro 32 bit??-3vol-cntrl-options.jpg Trouble getting sound to speakers W7 Pro 32 bit??-4bmanage-audio-devices.jpg Trouble getting sound to speakers W7 Pro 32 bit??-5bpc-devices-all.jpg Trouble getting sound to speakers W7 Pro 32 bit??-6bsound-sliders-3.jpg Trouble getting sound to speakers W7 Pro 32 bit??-7bsound-sliders-speaker.jpg Trouble getting sound to speakers W7 Pro 32 bit??-8bsound-test-no-sound.jpg Trouble getting sound to speakers W7 Pro 32 bit??-9bworks-monitor-speakers.jpg Trouble getting sound to speakers W7 Pro 32 bit??-11c-pc-back-input-panel.jpg Trouble getting sound to speakers W7 Pro 32 bit??-15d-stereo-pc-jack.jpg
05 Aug 2014   #7
carwiz
Windows 7 Pro-x64
The HDMI (display) is selected as the default output. If you want sound to appear at the speakers, select them as the default in the Playback Devices screen. Do your speakers have an A/C adapter for power or is the power drawn from the USB socket?
Your Akai shows AUX-IN. These are usually for high impedance devices like turntables. You can't attach the PC speaker output to these jacks since the PC speaker output is low impedance. You would need some type of converter/matcher.
Added: http://www.amazon.com/PYLE-PLVHL60-C...aker+converter
The above link shows one type of converter. You would have to add the input 3.5mm jack to plug into the PC speaker jack.
06 Aug 2014   #8
klxdrt
Carwiz,
Thanks for your quick response & patience in responding to my question. As my post mentioned, I can get sound thru my tiny monitor speakers so I'll just live that setup for now. And I have been able to use the small stereo with success for a yr by plugging in the black RCA jack into either back or front green speaker input.
Last week I used USB speakers plugged in as shown in my PC, they worked fine. HOWEVER, I was using a new monitor with the std blue monitor plug, NOT an HDMI cord and they worked fine with NO external power supply. Me thinks the problem is that I'm using an HDMI cord between PC & monitor at it provides both sound & video. That setup seems to supersedes connecting the stereo unit??
I originally built a visually merchandised 1 pg web, then was told by the form I should upload the images bit they were not in order even tho I numbered them, so I'm dropping this post question.
Cheers & thanks for all your help.
klx
I have been an avid audio enthusiast, music lover for 50+ yr. Below are some pix of my listing room. You won't believe how Pink Floyd's "Welcome to the machine" reproduces --- breathtaking. You are tempted to get out of the way of the machine as it advances.
Trouble getting sound to speakers W7 Pro 32 bit??-panorama-1200-listening-end-b.jpg   Trouble getting sound to speakers W7 Pro 32 bit??-panorama-1200-speaker-end-b.jpg
06 Aug 2014   #9
carwiz
Windows 7 Pro-x64
Ops, you're right. I forgot about the "new" PCs actually needing amplified speakers. I went to them years ago and never looked back. Sorry. (The converter/matcher is not required.)
Nice room! Wish I had the space. Most of my music is '67 and before. When "flower power" broke out, I lost interest. But I did go through a Disco and Pat Benatar period.
By default, yes, HDMI connections are set but they shouldn't be persistent. As I mentioned, you need to select the speakers as the default output. From then on, they should stay set as the PC output--Unless you disconnect them. That's how I'm set up now.
07 Aug 2014   #10
klxdrt
carwiz,
When I enabled the "speakers" as default and that wouldn't work. screen wnt blank & I had to reset my audio devices.
The images below represent my current config. I can only get sound thru monitor speakers.
Hope this helps??
cheers,
klx
Trouble getting sound to speakers W7 Pro 32 bit??-1-back-pc-p1040514.jpg   Trouble getting sound to speakers W7 Pro 32 bit??-2-sound-playing-config.jpg
Trouble getting sound to speakers W7 Pro 32 bit??-3-no-audio-devices-installed-2014-08-07_103605.jpg Trouble getting sound to speakers W7 Pro 32 bit??-4-re-enable-audio-devices2014-08-07_103709.jpg
The volume bar shows sound but no sound through speakers.
Hi, I am pretty stumped with this one. I upgraded my office to windows 7 32bit pro. 10 computers all the same, but one of them has audio issues. When I play the sample music the volume bar shows the equalizer bouncing like it is sending out audio, but any speakers I plug into it produce no...
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
Speakers; No Sound
No sound through speakers that were used with Pavillion 7955 being replaced with HP Pavillion p7-1154; No problems with speakers, still work with pc taken out of service. Unable to resolve problem, have gone through Troubleshooter, updated drivers, and other suggested fixes-nothing has worked. Any...
No sound from speakers but showing sound graph on speaker control
I have an MSI 785GTM-E45 Mother Board. I have no sound coming from the speakers. Tried new speakers and still no sound. If I click on the speaker Icon on the bottom right it shows the speaker graph going up and down as sound is being produced. I tried the head phones and nothing coming from them...
No sound from built in speakers, but sound from headphones
I have a Lenovo S10-3 Netbook, running on Win7 starter. It has been running fine unil a few days ago, when the built in speakers no longer play any sound. Works fine with earphones or exernal speakers, but not internal speakers. Drivers are all up to date, and audio/sound settings are all...
