Windows 7: Win 7 making sound on login sound scheme is set to none
03 Aug 2014   #1
banny35
Windows 7 Professional x64
I think the title says it all, when I log into Windows 7, it sitll makes a sound upon login even though sounds are set to none.
Thanks in advance for any assistance.
04 Aug 2014   #2
fireberd
Along with the "no sounds" scheme, there is a separate box to uncheck for the startup sound.
See this:
Win 7 making sound on login sound scheme is set to none-sound-scheme-capture.jpg
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound Scheme Changes
Running Windows 7 Pro I have created a sound scheme, named it and saved it. However, after every 2 or 3 boot-ups it reverts to the Windows Default scheme. How do I keep my scheme constant without Windows Default taking over? Thanks.
How do you Install Sound scheme
I am trying to make my windows look like a Mac. I only have one thing missing and that is the sound scheme. Is their away you can add all the sound scheme instead of choosing one by one. http://img715.imageshack.us/img715/2002/80466113.png
Windows 7 start up sound/login sound
Hi, iv just installed a fresh copy of windows 7 ultimate, and iv noticed something strange with the startup/welcome sound. The sound that windows plays to welcome you to the desktop seesm to execute before I even type my password in, and when I do type my password in, it plays the sound when...
Can you have 2 different sound scheme's
Does anyone know if you can save two different sound schemes? In other words, save some sounds with "windows default" and other sounds with a different sound scheme (control panel, sound, sounds tab, sound scheme). Thanks
Missing Sound Scheme(s)
I suddenly found my Windows Sound has no sound scheme. Things were fine after I installed the OS and the only change I made since then was switch back and forth between a couple of windows schemes that came with the OS. The entire list is blank under sound and when I try to add a sound...
