Windows 7: Customised alert sound for critical battery will not stop
09 Aug 2014   #1
JamesStarking
I have set a customised alert sound for my Windows 8 laptop's Critical Battery alert but when I plug the charger in the sound keeps going.
Is there a way I can have the sound play until the charger is plugged in and for it to then stop?
10 Aug 2014   #2
fireberd
Since this is a customized alert, whoever designed the alert may be able to change something.
10 Aug 2014   #3
JamesStarking
It was just a sound I downloaded and set myself. I basically just need to be able to set the sound to stop as soon as it senses the power has been reconnected
10 Aug 2014   #4
fireberd
That would be some type of Customization, even though it concerns a sound.
This is the forum section that is best for how to customize something.
Customization - Windows 7 Help Forums
'Battery Alert' appears before the 'press 'ESC' key for Start-up menu'
Hi, First of all: I know that I have been having a problem with my HP Laptop Battery, and with its cooling Fan. However, I am now wondering what detected this error below as long as it was shown even before the notification saying 'the press 'ESC' key for Start-up menu.' Thus, if the BIOS...
Hardware & Devices
No Desktop Pop Up Alert for Low Battery
I own two new Dell Laptops, one a Precision workstation and the other an everyday Latitude, both running Win 7 Pro. Both have new batteries, so that's not an issue. Please do not suggest I check my battery. My system power settings are correct for both AC power and on battery, so that's not a...
Performance & Maintenance
Windows Fails to Alert Battery Level and Shuts Down
Windows doesn't alert me of low battery power and the battery dies. It has been happening for the past couple of days now. I have checked the power plan settings and see that is is suppose to warn me at 16% and is suppose to hibernate at 9%. Anyone know what is causing it not to do either?
General Discussion
Run Script on Battery/Critical Power
Hi all, In XP, we had the option of executing a script when the computer switched from AC to battery power, and also when the battery reached a critical level. This was extremely useful because I had a special script run to send an email that the power had gone out and then hibernate the...
No low battery alert. How to on it?
Hey guys, i am using sony vaio s series. Whenever my battery reaches 10% it will auto hibernate(VERY ANNOYING as it cuts off my internet connection) it self until i plug in the power supply. Any idea how to make it alert me at 10% and when reaches 5% then auto hibernate?
General Discussion
critical battery sound volume level?
i have critical battery sound set on my laptop to turn on at 10% and then 7% and shut the computer down at 5% if i do not do anything about it. problem is, sometimes i have the volume real low or off and dont hear it. is it possible (in windows, not an external program, although i will look to...
