Windows 7: Default audio output is not plugged in
20 Aug 2014   #1
Smk911
Windows 7 Home 64bit
Hi, wasn't sure which thread to post this under, but this does say Sound and Audio. Earlier today I restored my computer back to its factory settings, and then proceeded to transfer files I had wanted to keep back onto it. Everything seemed pretty fine but now I am picking up NO audio through my monitor. I'm not too sure when this happened so cannot decipher what exactly may have caused it. I have my visual and audio setup connected to a TV screen via a HDMI cable. How am I supposed to repair or fix whatever has gone wrong? I plugged some headphones into one of the ports and it did pick up those as plugged in.
Any help would be fantastic as I'm quite close on giving up on this machine now.
20 Aug 2014   #2
dsperber
Audio playback device is set by the "playback devices" dialog, which you get to by RMB on the speaker icon in the System Tray. Select "playback devices", and then select your digital HDMI monitor and push the "set default" button at the bottom of the window.
Of course, you also need to have installed the relevant HDMI Audio driver for your video card (or from Realtek?). This is a separate HDMI Audio driver (i.e. separate from the video driver for your card) that would not necessarily come in your factory install, but for sure also needs to be installed to support audio via HDMI cable. Go to the video card web site driver support page (or Realtek?) and locate the HDMI Audio driver for your video card. Once it's installed the HDMI-connected monitor should appear in the list of "playback devices" and will allow you to "set default".
And now you should have audio through the speakers in the monitor, fed from the same HDMI cable that goes from video card to monitor for video.
20 Aug 2014   #3
Smk911
Thank you!
20 Aug 2014   #4
dsperber
Did you get it working?
need "always on top icon & msg for "default audio input/output device"
I need to always display the default audio input and audio output device currently on win7. Would like to launch a small program on change as well or instead. I tried to use task scheduler but was not able. Help! Thanks, Ray
AMD HDMI Output - Not Plugged In
Hello, friends! I'm tired off looking for answer. :( So I came here to look for help, I know you're smarter than me. I have ASUS Notebook X53U - SX155V So my problem is AMD HDMI Output - Not Plugged In . And my PC don't have sound at all. Even microphone don't work. I think it's not drivers...
Help Setting a Permanent "Default" Audio Output
I have a Samsung 24" monitor/TV combo as well a Turtle Beach X12 headset connected to my desktop at all times. I have been experiencing issues with my computer always choosing the monitor as the default audio output. I believe it may be because my computer detects my monitor before it detects...
Realtek HDMI Output ATI HDMI Audio -Not Plugged In-
I'm trying to hook up my TV with my computer, and for the most part it's working. The video goes through and I get how to control it and everything. The only thing not working is the sound. I'm using an HDMI to HDMI cable, and like I said the video is fine. Also, when the cable is plugged into...
how do i make mc7 default audio output separate from system default
I have searched the internet for a solution but am not able to find one. My issue is that i would like to be able to have media center audio play only through my tv and not through my pc main speaker system, tv is hooked through hdmi output on graphics card, speaker system through 5.1 output on...
Media Center
can't set front jack as default audio output (notebook)
Hi !'ve got a probelm with my compaq 615 i had a problem with my audio quitting on me after the laptop went to sleep (which required a reboot) so i reinstalled the drivers (IDT HD) now my laptop speakers are set as the default audio device and my headphone jack is set as the default...
