Windows 7: Realtek high definition audio max volume is about 50% than before,help
26 Aug 2014   #11
midou35000
Windows 7 Pro
Yes of course you can but first just test it on another pc so we can make sure it is not your PC or OS that have the problem .
26 Aug 2014   #12
tadasjag
Okey, so ill be back on this thread in about 2 days with the results thank you for your time and after few days, i will ask for some more of your time )
27 Aug 2014   #13
tadasjag
This is how my max sound look like.................... View image: dfggdggdgggg
27 Aug 2014   #14
midou35000
Windows 7 Pro
Well that depends because you cant controll that sound coming from the .mp3 file.
30 Aug 2014   #15
rvcjew
7 Pro x64, 10 Pro x64
In playback properties of the device what are the levels set at? Also what is the program your using to play back the music?
01 Sep 2014   #16
tadasjag
all 100%. I use aimp3 player and sometimes vlc media player for higher sound...
19 Sep 2014   #17
tadasjag
http://p.globalsources.com/IMAGES/PD...Capacitors.jpg
Solved, all 20 capacitors were dead through 9 years of using.
Microsoft High Definition Driver vs Realtek high definition audio driv
Microsoft High Definition Driver vs Realtek high definition audio driver?
Drivers
Realtek High Definition Audio and Intel Display Audio
I think my question is this: how do I set up VSX-1124 (a Pioneer AVR) in Control Panel/Sound and Hardware/Sound so that its driver is Realtek HD Audio and not the Intel Display Audio one? In Device Manager under Sound, Video and game controllers, I have two sound card drivers, Realtek High...
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
Realtek High Definition Audio, No Sound
This is the second time this has happened. My audio is not working. No output at all. My audio card is motherboard integrated. As said in the title, it is Realtek High Definition Audio (Speakers). Like I also said, this is the second time this has happened. Last time, I reinstalled my drivers...
Realtek & high definition audio?
HEY Everyone,I do not know if i have been the biggest dummie on the planet eart,i have installet high definition audio drivers witch i thourgt came from REALTEK,but when i open audiounits there only is high definition audio and before it said:realtek high definition audio,there is not ecxatly a...
Realtek High Definition Audio problem
Hi guys..now we all know ...this is golbal problem..i have instaled my windows 7 ultimate x86 and no drivers works for me...like always :Code 10 problem ...last time ..a xp driver works ...but i can't remember the version that i used... Maybe this will help you...
Drivers
