Windows 7: Realtek high definition audio max volume is about 50% than before,help
26 Aug 2014   #1
tadasjag
hello. At some point I chose to reinstall Windows. I installed and updated all the drivers, etc and set the speakers up the same way as before. Only this time the audio was around 50% of the volume it was previously with volume up full. I reinstalled all audio drivers 5 times already, dont know what to do... i am running creative speakers 5.1. The drivers i have are : View image: fghfghfghfgh
I use green jack for front speakers , blue for rear speakers and pink for center/subwoofer. Please help, i want to get my full capacity sound!! (((
26 Aug 2014   #2
midou35000
Windows 7 Pro
Hi tadasjag and Welcome to Seven Forums,
Can you roll back the driver and see if it fixes the problem?
26 Aug 2014   #3
tadasjag
Quote   Quote: Originally Posted by midou35000 View Post
i rolled them back, now my audio manager is gone and i have only stereo speakers, need to download good manager to set jack for center, and rear speaker, cause i hear only stereo
26 Aug 2014   #4
midou35000
Windows 7 Pro
Do you see in the screen shot you gave me there is a "Roll Back Driver" button over there click it (not in the picture) and follow the steps and it should roll that driver to an earlier version and it should work.
26 Aug 2014   #5
tadasjag
Yes i rolled them back, now im missing audio manager where i can setup 5.1. in playback devices through speakers, i can only pick stereo now
26 Aug 2014   #6
midou35000
Windows 7 Pro
Yes because its an old version you can now update the driver to its newest version and if you get the volume error back then it must an error with the driver not your PC.
26 Aug 2014   #7
tadasjag
oky, then im going for the update and will post if it fixed
26 Aug 2014   #8
tadasjag
It didint fix the problem ... when i man this thingy http://g-ecx.images-amazon.com/image.../6300-5_lg.jpg the max sound is like my laptops dell inspirion 15r sound when it should be 3 times greater.. (
26 Aug 2014   #9
midou35000
Windows 7 Pro
Maybee its a driver problem can you try it on your neighbor or friend's PC?
26 Aug 2014   #10
tadasjag
hm, i have a pc that i took for repairs, ill try the speakers on it. But IF the problem continues, is it possible to download some other drivers? Mother board: H61m-DS2
I can test the speaker only in a day or 2. Need parts for the other pc to make it working.
Microsoft High Definition Driver vs Realtek high definition audio driv
Microsoft High Definition Driver vs Realtek high definition audio driver?
Drivers
Realtek High Definition Audio and Intel Display Audio
I think my question is this: how do I set up VSX-1124 (a Pioneer AVR) in Control Panel/Sound and Hardware/Sound so that its driver is Realtek HD Audio and not the Intel Display Audio one? In Device Manager under Sound, Video and game controllers, I have two sound card drivers, Realtek High...
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
Realtek High Definition Audio, No Sound
This is the second time this has happened. My audio is not working. No output at all. My audio card is motherboard integrated. As said in the title, it is Realtek High Definition Audio (Speakers). Like I also said, this is the second time this has happened. Last time, I reinstalled my drivers...
Realtek & high definition audio?
HEY Everyone,I do not know if i have been the biggest dummie on the planet eart,i have installet high definition audio drivers witch i thourgt came from REALTEK,but when i open audiounits there only is high definition audio and before it said:realtek high definition audio,there is not ecxatly a...
Realtek High Definition Audio problem
Hi guys..now we all know ...this is golbal problem..i have instaled my windows 7 ultimate x86 and no drivers works for me...like always :Code 10 problem ...last time ..a xp driver works ...but i can't remember the version that i used... Maybe this will help you...
Drivers
